Datasheet AD847 (Analog Devices) - 9
DescriptionHigh Speed, Low Power Monolithic Op Amp
Pages / Page14 / 9 — AD847. 100. V =. 1V p-p. R = 1k. CMR – dB. OUTPUT VOLTAGE – Volts p–p. …
RevisionF
File Format / SizePDF / 281 Kb
AD847. 100. V =. 1V p-p. R = 1k. CMR – dB. OUTPUT VOLTAGE – Volts p–p. 10k. 100k. 10M. 100M. FREQUENCY – Hz. INPUT FREQUENCY – Hz. –70. –80. 3V RMS
AD847 100 V = 1V p-p R = 1k CMR – dB OUTPUT VOLTAGE – Volts p–p 10k 100k 10M 100M FREQUENCY – Hz INPUT FREQUENCY – Hz –70 –80 3V RMS
AD847 100 30 25 80 V =
1V p-p CM 20 60 R = 1k
L 15 CMR – dB 40 10 OUTPUT VOLTAGE – Volts p–p 20 5 0 0 1k 10k 100k 1M 10M 100M 1M 10M 100M FREQUENCY – Hz INPUT FREQUENCY – Hz
Figure 13. Common-Mode Rejection vs. Frequency Figure 14. Large Signal Frequency Response
10 –70 8 –80 6 3V RMS
V R =1k
L 4 –90 2ND HARMONIC 2 1% 0.1% –100 0 1% 0.1% –2 –110 –4 3RD HARMONIC HARMONIC DISTORTION – dB OUTPUT SWING FROM 0 TO –6 –120 –8 –10 –130 0 20 40 60 80 100 120 140 160 100 1k 10k 100k SETTLING TIME – ns FREQUENCY – Hz
Figure 15. Output Swing and Error vs. Settling Time Figure 16. Harmonic Distortion vs. Frequency
50 450 400 Hz 40
µ
s 350 30 300 20 SLEW RATE – V/ 250 10 INPUT VOLTAGE NOISE – nV/ 200 0 150 10 100 1k 10k 100k 1M 10M –60 –40 –20 0 20 40 60 80 100 120 140 FREQUENCY – Hz TEMPERATURE –
C
Figure 17. Input Voltage Noise Spectral Density Figure 18. Slew Rate vs. Temperature REV. F –7–
