Datasheet LTC2274 (Analog Devices) - 3
Description | 16-Bit, 105Msps Serial Output ADC (JESD204) |
Pages / Page | 40 / 3 — ANALOG INPUT. The. denotes denotes the specifi cations which apply over … |
File Format / Size | PDF / 924 Kb |
ANALOG INPUT. The. denotes denotes the specifi cations which apply over the full operating temperature range,
LTC2274
ANALOG INPUT The
denotes denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
V + – IN Analog Input Range (AIN – AIN ) 3.135V ≤ VDD ≤ 3.465V l 1.5 or 2.25 VP-P VIN, CM Analog Input Common Mode Differential Input (Note 7) l 1 1.25 1.5 V I + – IN Analog Input Leakage Current 0V ≤ AIN , AIN ≤ VDD (Note 10) l –1 1 μA ISENSE SENSE Input Leakage Current 0V ≤ SENSE ≤ VDD (Note 11) –3 3 μA CIN Analog Input Capacitance Sample Mode ENC+ < ENC– 6.7 pF Hold Mode ENC+ > ENC– 1.8 pF tAP Sample-and-Hold 1 ns Acquisition Delay Time tJITTER Sample-and-Hold 80 fsRMS Acquisition Delay Time Jitter CMRR Analog Input 1V < (A + – IN = AIN ) <1.5V 80 dB Common Mode Rejection Ratio BW-3dB Full Power Bandwidth RS ≤ 25Ω 700 MHz
DYNAMIC ACCURACY The
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C. AIN = –1dBFS. (Note 4) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
SNR Signal-to-Noise Ratio 5MHz Input (2.25V Range, PGA = 0) 77.6 dBFS 5MHz Input (1.5V Range, PGA = 1) 75.4 dBFS 15MHz Input (2.25V Range, PGA = 0), TA = 25°C 76.5 77.5 dBFS 15MHz Input (2.25V Range, PGA = 0) l 76.2 77.2 dBFS 15MHz Input (1.5V Range, PGA = 1) 75.3 dBFS 70MHz Input (2.25V Range, PGA = 0) 77.2 dBFS 70MHz Input (1.5V Range, PGA = 1) 75.1 dBFS 140MHz Input (2.25V Range, PGA = 0) 76.3 dBFS 140MHz Input (1.5V Range, PGA = 1), TA = 25°C 73.8 74.5 dBFS 140MHz Input (1.5V Range, PGA = 1) l 73.4 74.2 dBFS 170MHz Input (2.25V Range, PGA = 0) 75.9 dBFS 170MHz Input (1.5V Range, PGA = 1) 74.3 dBFS SFDR Spurious Free Dynamic Range 5MHz Input (2.25V Range, PGA = 0) 100 dBc 2nd or 3rd Harmonic 5MHz Input (1.5V Range, PGA = 1) 100 dBc 15MHz Input (2.25V Range, PGA = 0), TA = 25°C 85 95 dBc 15MHz Input (2.25V Range, PGA = 0) l 84 95 dBc 15MHz Input (1.5V Range, PGA = 1) 100 dBc 70MHz Input (2.25V Range, PGA = 0) 86 dBc 70MHz Input (1.5V Range, PGA = 1) 94 dBc 140MHz Input (2.25V Range, PGA = 0) 85 dBc 140MHz Input (1.5V Range, PGA = 1), TA = 25°C 81 90 dBc 140MHz Input (1.5V Range, PGA = 1) l 80 89 dBc 170MHz Input (2.25V Range, PGA = 0) 80 dBc 170MHz Input (1.5V Range, PGA = 1) 85 dBc 2274fb 3
