Datasheet LTC2411, LTC2411-1 (Analog Devices) - 9
Description24-Bit No Latency ∆Σ™ ADC with Differential Input and Reference in MSOP
Pages / Page42 / 9 — TYPICAL PERFORMANCE CHARACTERISTICS. Conversion Current. Sleep Mode …
File Format / SizePDF / 598 Kb
TYPICAL PERFORMANCE CHARACTERISTICS. Conversion Current. Sleep Mode Current. vs Temperature. vs Output Data Rate
TYPICAL PERFORMANCE CHARACTERISTICS Conversion Current Sleep Mode Current vs Temperature vs Output Data Rate
LTC2411/LTC2411-1
TYPICAL PERFORMANCE CHARACTERISTICS Conversion Current Conversion Current Sleep Mode Current vs Temperature vs Output Data Rate vs Temperature
240 650 5 FO = GND REF+ = VCC FO = GND 230 CS = GND 600 REF– = GND CS = VCC SCK = NC IN+ = GND 550 4 SCK = NC 220 SDO = NC VCC = 5.5V IN– = GND SDO = NC 500 TA = 25°C 210 SCK = NC VCC = 5.5V 450 SDO = NC 3 VCC = 5V CS = GND 200 400 FO = EXT OSC 190 350 2 VCC = 5V VCC = 5V V 300 CC = 3V SUPPLY CURRENT (µA) CONVERSION CURRENT (µA) 180 250 SLEEP MODE CURRENT (µA) 1 VCC = 3V 170 VCC = 2.7V 200 VCC = 3V VCC = 2.7V 160 150 0 –45 –30 –15 0 15 30 45 60 75 90 0 5 10 15 20 25 –45 –30 –15 0 15 30 45 60 75 90 TEMPERATURE (°C) OUTPUT DATA RATE (READINGS/SEC) TEMPERATURE (°C) 2411 G25 2411 G26 2411 G27
Resolution (NOISERMS ≤ 1LSB) Resolution (INLMAX ≤ 1LSB) Offset Error vs Output Data Rate vs Output Data Rate vs Output Data Rate
40 22 22 V 20 VREF = 5V REF = 2.5V ) V 20 REF = 2.5V REF 0 21 V V REF = 5V REF = 5V 18 –20 VREF = 2.5V –40 20 16 V VCC = 5V –60 CC = 5V VCC = 5V REF– = GND REF– = GND REF– = GND RESOLUTION (BITS) VINCM = 2.5V RESOLUTION (BITS) 14 VINCM = 2.5V –80 VINCM = 2.5V 19 VIN = 0V VIN = 0V OFFSET ERROR (ppm OF V VIN = 0V FO = EXT OSC 12 FO = EXT OSC –100 FO = EXT OSC RES = LOG2(VREF/NOISERMS) RES = LOG2(VREF/INLMAX) TA = 25°C TA = 25°C TA = 25°C –120 18 10 0 5 10 15 20 25 0 5 10 15 20 25 0 5 10 15 20 25 OUTPUT DATA RATE (READINGS/SEC) OUTPUT DATA RATE (READINGS/SEC) OUTPUT DATA RATE (READINGS/SEC) 2411 G28 2411 G29 2411 G30 2411fa For more information www.linear.com/LTC2411 9
