Datasheet LTM9012 (Analog Devices) - 4
DescriptionQuad 14-Bit, 125Msps ADC with Integrated Drivers
Pages / Page28 / 4 — inTernal reFerence characTerisTics. The. denotes the specifications which …
inTernal reFerence characTerisTics. The. denotes the specifications which apply over the
inTernal reFerence characTerisTics The denotes the specifications which apply over the
LTM9012
VREF Output Voltage IOUT = 0 1.225 1.250 1.275 V VREF Output Temperature Drift ±25 ppm/°C VREF Output Resistance –400μA < IOUT < 1mA 7 Ω VREF Line Regulation 1.7V < VDD < 1.9V 0.6 mV/V
DigiTal inpuTs anD ouTpuTs The
denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. (Note 6) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS ENCODE INPUTS (ENC+, ENC–) Differential Encode Mode (ENC– Not Tied to GND)
VID Differential Input Voltage (Note 9) l 0.2 V VICM Common Mode Input Voltage Internally Set 1.2 V Externally Set (Note 9) l 1.1 1.6 V VIN Input Voltage Range ENC+, ENC– to GND l 0.2 3.6 V RIN Input Resistance (See Figure 3) 10 kΩ CIN Input Capacitance 3.5 pF
Single-Ended Encode Mode (ENC– Tied to GND)
VIH High Level Input Voltage VDD = 1.8V 1.26 V VIL Low Level Input Voltage VDD = 1.8V 0.54 V VIN Input Voltage Range ENC+ to GND 0 to 3.6 V RIN Input Resistance (See Figure 4) 30 kΩ CIN Input Capacitance 3.5 pF
Digital Inputs (CS, SDI, SCK in Serial or Parallel Programming Mode. SDO in Parallel Programming Mode)
VIH High Level Input Voltage VDD = 1.8V l 1.3 V VIL Low Level Input Voltage VDD = 1.8V l 0.6 V IIN Input Current VIN = 0V to 3.6V l –10 10 µA CIN Input Capacitance 3 pF
SDO Output (Serial Programming Mode. Open-Drain Output. Requires 2k Pull-Up Resistor if SDO is Used)
ROH Logic Low Output Resistance to GND VDD = 1.8V, SDO = 0V 200 Ω IOH Logic High Output Leakage Current SDO = 0V to 3.6V l –10 10 µA COUT Output Capacitance 3 pF
Digital Input (SHDN)
VIH High Level Input Voltage VCC = 3.3V l 0.97 1.4 V VIL Low Level Input Voltage VCC = 3.3V l 0.6 0.95 V RSHDN SHDN Pull-Up Resistor VSHDN = 0V to 0.5V l 90 150 210 kΩ
Digital Data Outputs
VOD Differential Output Voltage 100Ω Differential Load, 3.5mA Mode l 247 350 454 mV 100Ω Differential Load, 1.75mA Mode l 125 175 250 mV VOS Common Mode Output Voltage 100Ω Differential Load, 3.5mA Mode l 1.125 1.250 1.375 V 100Ω Differential Load, 1.75mA Mode l 1.125 1.250 1.375 V RTERM On-Chip Termination Resistance Termination Enabled, OVDD = 1.8V 100 Ω 9012fa 4 For more information www.linear.com/LTM9012 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Converter Characteristics Analog Input Dynamic Accuracy Internal Reference Characteristics Digital Inputs and Outputs Power Requirements Timing Characteristics Electrical Characteristics Timing Diagrams Typical Performance Characteristics Pin Functions Pin Configuration Table Block Diagram Applications Information Typical Application Package Description Revision History Typical Application Related Parts
