Datasheet AD7851 (Analog Devices) - 10
Description14-Bit, 333 kSPS, Serial Sampling A/D Converter
Pages / Page37 / 10 — AD7851. PIN FUNCTION DESCRIPTIONS. Pin No. Mnemonic Description
File Format / SizePDF / 436 Kb
AD7851 PIN FUNCTION DESCRIPTIONS Pin No Mnemonic Description
AD7851 PIN FUNCTION DESCRIPTIONS Pin No. Mnemonic Description
1 CONVST Convert Start. Logic input. A low-to-high transition on this input puts the track-and-hold into its hold mode and starts conversion. When this input is not used, it should be tied to DVDD. 2 BUSY Busy Output. The busy output is triggered high by the falling edge of CONVST or rising edge of CAL and remains high until conversion is completed. BUSY is also used to indicate when the AD7851 has completed its on-chip calibration sequence. 3 SLEEP Sleep Input/Low Power Mode. A Logic 0 initiates a sleep and all circuitry is powered down, including the internal voltage reference, provided there is no conversion or calibration being performed. Calibration data is retained. A Logic 1 results in normal operation. See Power-Down section for more details. 4 REFIN/ Reference Input/Output. This pin is connected to the internal reference through a series resistor and is the REFOUT reference source for the analog-to-digital converter. The nominal reference voltage is 4.096 V and this appears at the pin. This pin can be overdriven by an external reference or can be taken as high as AVDD. When this pin is tied to AVDD, or when an externally applied reference approaches VDD, then the CREF1 pin should also be tied to AVDD. 5 AVDD Analog Positive Supply Voltage, 5.0 V ± 5%. 6, 12 AGND Analog Ground. Ground reference for track and hold, reference, and DAC. 7 CREF1 Reference Capacitor (0.1 µF ceramic disc in parallel with a 470 nF tantalum). This external capacitor is used as a charge source for the internal DAC. The capacitor should be tied between the pin and AGND. 8 CREF2 Reference Capacitor (0.01 µF ceramic disc). This external capacitor is used in conjunction with the on-chip reference. The capacitor should be tied between the pin and AGND. 9 AIN(+) Analog Input. Positive input of the pseudo-differential analog input. Cannot go below AGND or above AVDD at any time and cannot go below AIN(–) when the unipolar input range is selected. 10 AIN(–) Analog Input. Negative input of the pseudo-differential analog input. Cannot go below AGND or above AVDD at any time. 11 NC No Connect Pin. 13 AMODE Analog Mode Pin. This pin allows two different analog input ranges to be selected. A Logic 0 selects range 0 to VREF (i.e., AIN(+) – AIN(–) = 0 to VREF). In this case, AIN(+) cannot go below AIN(–) and AIN(–) cannot go below AGND. A Logic 1 selects range –VREF/2 to +VREF/2 (i.e., AIN(+) – AIN(–) = –VREF /2 to +VREF/2). In this case, AIN(+) cannot go below AGND so that AIN(–) needs to be biased to +VREF/2 to allow AIN(+) to go from 0 V to +VREF V. 14 POLARITY Serial Clock Polarity. This pin determines the active edge of the serial clock (SCLK). Toggling this pin will reverse the active edge of the serial clock (SCLK). A Logic 1 means that the serial clock (SCLK) idles high and a Logic 0 means that the serial clock (SCLK) idles low. It is best to refer to the timing diagrams and Table IX for the SCLK active edges. 15 SM1 Serial Mode Select Pin. This pin is used in conjunction with the SM2 pin to give different modes of opera- tion as described in Table X. 16 SM2 Serial Mode Select Pin. This pin is used in conjunction with the SM1 pin to give different modes of opera- tion as described in Table X. 17 CAL Calibration Input. This pin has an internal pull-up current source of 0.15 µA. A Logic 0 on this pin resets all calibration control logic and initiates a calibration on its rising edge. There is the option of connecting a 10 nF capacitor from this pin to DGND to allow for an automatic self-calibration on power-up. This input overrides all other internal operations. If the autocalibration is not required, then this pin should be tied to a logic high. 18 DVDD Digital Supply Voltage, 5.0 V ± 5%. 19 DGND Digital Ground. Ground reference point for digital circuitry. 20 DOUT Serial Data Output. The data output is supplied to this pin as a 16-bit serial word. 21 DIN Serial Data Input. The data to be written is applied to this pin in serial form (16-bit word). This pin can act as an input pin or as a input and output pin depending on the serial interface mode the part is in (see Table X). 22 CLKIN Master Clock Signal for the Device (6 MHz or 7 MHz). Sets the conversion and calibration times. 23 SCLK Serial Port Clock. Logic input/output. The SCLK pin is configured as an input or output, dependent on the type of serial data transmission (self-clocking or external-clocking) that has been selected by the SM1 and SM2 pins. The SCLK idles high or low depending on the state of the POLARITY pin. 24 SYNC This pin can be an input level triggered active low (similar to a chip select in one case and to a frame sync in the other) or an output (similar to a frame sync) pin depending on SM1, SM2 (see Table X). REV. B –9– Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION PRODUCT HIGHLIGHTS TABLE OF CONTENTS SPECIFICATIONS TIMING SPECIFICATIONS TYPICAL TIMING DIAGRAMS ABSOLUTE MAXIMUM RATINGS PINOUT FOR DIP, SOIC, AND SSOP ORDERING GUIDE TERMINOLOGY Integral Nonlinearity Differential Nonlinearity Total Unadjusted Error Unipolar Offset Error Positive Full-Scale Error Negative Full-Scale Error Bipolar Zero Error Track-and-Hold Acquisition Time Signal-to-(Noise + Distortion) Ratio Total Harmonic Distortion Peak Harmonic or Spurious Noise Intermodulation Distortion Power Supply Rejection Ratio (PSRR) Full Power Bandwidth (FPBW) PIN FUNCTION DESCRIPTIONS AD7851 ON-CHIP REGISTERS Addressing the On-Chip Registers Writing Reading CONTROL REGISTER STATUS REGISTER CALIBRATION REGISTERS Addressing the Calibration Registers Writing to/Reading from the Calibration Registers Adjusting the Offset Calibration Register Adjusting the Gain Calibration Register CIRCUIT INFORMATION CONVERTER DETAILS TYPICAL CONNECTION DIAGRAM ANALOG INPUT Acquisition Time DC/AC Applications Input Ranges Transfer Functions REFERENCE SECTION AD7851 PERFORMANCE CURVES POWER-DOWN OPTIONS POWER-UP TIMES Using an External Reference Using the Internal (On-Chip) Reference POWER VS. THROUGHPUT RATE CALIBRATION SECTION Calibration Overview Automatic Calibration on Power-On Self-Calibration Description Self-Calibration Timing System Calibration Description System Gain and Offset Interaction System Calibration Timing SERIAL INTERFACE SUMMARY Resetting the Serial Interface DETAILED TIMING SECTION Mode 1 (2-Wire 8051 Interface) Mode 2 (3-Wire SPI/QSPI Interface Mode) Mode 3 (QSPI Interface Mode) MODE 4 and 5 (Self-Clocking Modes) CONFIGURING THE AD7851 AD7851 as a Read-Only ADC Writing to the AD7851 Interface Modes 2 and 3 Configuration Interface Mode 1 Configuration Interface Modes 4 and 5 Configuration MICROPROCESSOR INTERFACING AD7851 to 8XC51/PIC17C42 Interface AD7851 to 68HC11/16/L11/PIC16C42 Interface AD7851 to ADSP-21xx Interface AD7851 to DSP56000/1/2/L002 Interface AD7851 to TMS320C20/25/5x/LC5x Interface APPLICATION HINTS Grounding and Layout Evaluating the AD7851 Performance AD785x Family OUTLINE DIMENSIONS Revision History
