Datasheet HMC602LP4, 602LP4E (Analog Devices) - 4
Description70 dB, Logarithmic Detector/Controller SMT, 1 - 8000 MHz
Pages / Page10 / 4 — HMC602LP4 / 602LP4E. 70 dB, LOGARITHMIC. DETECTOR / CONTROLLER, 1 - 8000 …
File Format / SizePDF / 598 Kb
HMC602LP4 / 602LP4E. 70 dB, LOGARITHMIC. DETECTOR / CONTROLLER, 1 - 8000 MHz. Electrical Specifi cations, (continued)
HMC602LP4 / 602LP4E 70 dB, LOGARITHMIC DETECTOR / CONTROLLER, 1 - 8000 MHz Electrical Specifi cations, (continued)
HMC602LP4 / 602LP4E
v03.0209
Parameter Conditions Min. Typ. Max. Units Open Loop Corner Frequency 700 kHz
Power Down (EN) Interface
Voltage Range for Normal Mode 0.8 x Vcc [4] Vcc [4] V Voltage Range for Powerdown Mode 0 0.2 x Vcc [4] V Threshold Voltage Vcc [4]/2 V
Power Supply (Vcc1, Vcc2, Vcc3)
Operating Voltage Range 4.5 5.5 V Supply Current in Normal Mode 113 mA Supply Current in Power Down Mode 1 mA [4] Vcc= Vcc1= Vcc2= Vcc3= +5V
Test Conditions
12 Parameter Condition Vcc1, Vcc2, Vcc3 +5V Input Zo 50Ω T T +25C A Fin 900 MHz
LOGOUT Voltage & Error LOGOUT Voltage & Error vs. Input Power, Fin = 50 MHz vs. Input Power, Fin = 100 MHz
S - SM 2.6 4 2.6 4 R ERR +25C ERR +25C O ERR +85C ERR +85C ERR -40C ERR -40C T 2 2 2 2 C ERROR (dB) ERROR (dB) E 1.4 0 1.4 0 T E LOGOUT (V) LOGOUT (V) 0.8 -2 Ideal 0.8 Ideal -2 LOGOUT +25C LOGOUT +25C LOGOUT +85C LOGOUT +85C R D LOGOUT -40C LOGOUT -40C E 0.2 -4 0.2 -4 -70 -60 -50 -40 -30 -20 -10 0 10 -70 -60 -50 -40 -30 -20 -10 0 10 W INPUT POWER (dBm) INPUT POWER (dBm) O P
LOGOUT Voltage & Error LOGOUT Voltage & Error vs. Input Power, Fin = 900 MHz vs. Input Power, Fin = 1900 MHz
2.6 4 2.6 4 ERR +25C ERR +25C ERR +85C ERR +85C ERR -40C 2 2 2 ERR -40C 2 ERROR (dB) ERROR (dB) 1.4 0 1.4 0 LOGOUT (V) LOGOUT (V) 0.8 Ideal -2 0.8 -2 Ideal LOGOUT +25C LOGOUT +25C LOGOUT +85C LOGOUT +85C LOGOUT -40C LOGOUT -40C 0.2 -4 0.2 -4 -70 -60 -50 -40 -30 -20 -10 0 10 -70 -60 -50 -40 -30 -20 -10 0 10 INPUT POWER (dBm) INPUT POWER (dBm) Unless otherwise noted: Vcc1, Vcc2, Vcc3 = +5V, TA = +25C Information furnis F heod r pri by An ce, de alog Devi lcievs eir s y b , a eliev nd to pla ed to be accu ce o rate anrder d relia sbl, pl e. H ease co owever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone: 978 rights of third parties that may result from its use. Specifications subject to change without notice. No Ph - o 25 ne 0 : 7 -3 81- 3 3 4 29 3 F -470 ax: 978 0 • Orde - r o 25 nlin 0- e a3 t 373 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
12 - 19
Order On-l Trademarks and registered trademarks are the property of their respective owners. ine at www.hit A ti p te.co plicati m on Support: Phone: 1-800-ANALOG-D
