Datasheet Datasheet ATtiny24A, ATtiny44A, ATtiny84A. Summary (Microchip) - 6
ManufacturerMicrochip
Description8-bit Microcontroller with 2K/4K/8K Bytes In-System Programmable Flash
Pages / Page22 / 6 — General Information. 3.1. Resources. 3.2. Code Examples. 3.3. Capacitive …
File Format / SizePDF / 707 Kb
General Information. 3.1. Resources. 3.2. Code Examples. 3.3. Capacitive Touch Sensing. 3.4. Data Retention. 3.5. Disclaimer
General Information 3.1 Resources 3.2 Code Examples 3.3 Capacitive Touch Sensing 3.4 Data Retention 3.5 Disclaimer
3. General Information 3.1 Resources
A comprehensive set of drivers, application notes, data sheets and descriptions on development tools are available for download at http://www.atmel.com/avr.
3.2 Code Examples
This documentation contains simple code examples that briefly show how to use various parts of the device. These code examples assume that the part specific header file is included before compilation. Be aware that not all C compiler vendors include bit definitions in the header files and interrupt handling in C is compiler dependent. Please confirm with the C compiler documen- tation for more details. For I/O Registers located in the extended I/O map, “IN”, “OUT”, “SBIS”, “SBIC”, “CBI”, and “SBI” instructions must be replaced with instructions that allow access to extended I/O. Typically, this means “LDS” and “STS” combined with “SBRS”, “SBRC”, “SBR”, and “CBR”. Note that not all AVR devices include an extended I/O map.
Atmel QTouch Library provides a simple to use solution for touch sensitive interfaces on Atmel AVR microcontrollers. The QTouch Library includes support for QTouch® and QMatrix® acquisi- tion methods. Touch sensing is easily added to any application by linking the QTouch Library and using the Application Programming Interface (API) of the library to define the touch channels and sensors. The application then calls the API to retrieve channel information and determine the state of the touch sensor. The QTouch Library is free and can be downloaded from the Atmel website. For more informa- tion and details of implementation, refer to the QTouch Library User Guide – also available from the Atmel website.
3.4 Data Retention
Reliability Qualification results show that the projected data retention failure rate is much less than 1 PPM over 20 years at 85°C or 100 years at 25°C.
3.5 Disclaimer
Typical values contained in this datasheet are based on simulations and characterization of other AVR microcontrollers manufactured on the same process technology. Min and Max values will be available after the device has been characterized.
6 ATtiny24A/44A/84A
8183FS–AVR–06/12 Document Outline Features 1. Pin Configurations 1.1 Pin Descriptions 1.1.1 VCC 1.1.2 GND 1.1.3 Port B (PB3:PB0) 1.1.4 RESET 1.1.5 Port A (PA7:PA0) 2. Overview 3. General Information 3.1 Resources 3.2 Code Examples 3.3 Capacitive Touch Sensing 3.4 Data Retention 3.5 Disclaimer 4. Register Summary 5. Instruction Set Summary 6. Ordering Information 6.1 ATtiny24A 6.2 ATtiny44A 6.3 ATtiny84A 7. Packaging Information 7.1 14S1 7.2 14P3 7.3 15CC1 7.4 20M1 7.5 20M2 8. Errata 8.1 ATtiny24A 8.1.1 Rev. H 8.1.2 Rev. G 8.1.3 Rev. F 8.2 ATtiny44A 8.2.1 Rev. G 8.2.2 Rev. F 8.2.3 Rev. E 8.3 ATtiny84A 8.3.1 Rev. C 9. Datasheet Revision History 9.1 Rev. 8183F – 06/12 9.2 Rev. 8183E – 01/12 9.3 Rev. 8183D – 04/11 9.4 Rev. 8183C – 03/11 9.5 Rev. 8183B – 03/10 9.6 Rev. 8183A – 12/08
