Datasheet ADA4841-2KGD (Analog Devices) - 4
DescriptionLow Power, Low Noise and Distortion, Rail-to-Rail Output Amplifier
Pages / Page9 / 4 — ADA4841-2KGD. Known Good Die. 5 V SUPPLY. Table 2. Parameter Test. …
File Format / SizePDF / 164 Kb
ADA4841-2KGD. Known Good Die. 5 V SUPPLY. Table 2. Parameter Test. Conditions/Comments. Min. Typ. Max. Unit
ADA4841-2KGD Known Good Die 5 V SUPPLY Table 2 Parameter Test Conditions/Comments Min Typ Max Unit
TA = 25°C, RL = 1 kΩ, G = +1, VCM = 2.5 V, unless otherwise noted.
Table 2. Parameter Test Conditions/Comments Min Typ Max Unit
DYNAMIC PERFORMANCE −3 dB Bandwidth VO = 0.02 V p-p 80 MHz VO = 2 V p-p 3 MHz Slew Rate G = +1, VO = 4 V step, RL = 1 kΩ 12 V/μs Settling Time to 0.1% G = +1, VO = 2 V step 175 ns Settling Time to 0.01% G = +1, VO = 2 V step 550 ns NOISE/HARMONIC PERFORMANCE Harmonic Distortion, HD2/HD3 fC = 100 kHz, VO = 2 V p-p −109/−105 dBc fC = 1 MHz, VO = 2 V p-p −78/−66 dBc Input Voltage Noise f = 100 kHz 2.1 nV/√Hz Input Current Noise f = 100 kHz 1.4 pA/√Hz Crosstalk f = 100 kHz −117 dB DC PERFORMANCE Input Offset Voltage 40 300 μV Input Offset Voltage Drift 1 μV/°C Input Bias Current 3 5.3 μA Input Offset Current 0.1 0.4 μA Open-Loop Gain VO = 0.5 V to 4.5 V 103 124 dB INPUT CHARACTERISTICS Input Resistance Common Mode 90 MΩ Differential Mode 25 kΩ Input Capacitance Common Mode 1 pF Differential Mode 3 pF Input Common-Mode Voltage Range −0.1 +4 V Common-Mode Rejection Ratio (CMRR) VCM = Δ1.5 V 88 115 dB MATCHING CHARACTERISTICS Input Offset Voltage 70 μV Input Bias Current 70 nA OUTPUT CHARACTERISTICS Output Voltage Swing G > +1 0.08 to 4.92 0.029 to 4.974 V Output Current Limit Sourcing, VIN = +VS, RL = 50 Ω to VCM 30 mA Sinking, VIN = −VS, RL = 50 Ω to VCM 60 mA Capacitive Load Drive 30% overshoot 15 pF POWER SUPPLY Operating Range 2.7 12 V Quiescent Current per Amplifier 1.1 1.4 mA Positive Power Supply Rejection Ratio +VS = +5 V to +6 V, −VS = 0 V 95 110 dB Negative Power Supply Rejection Ratio +VS = +5 V, −VS = 0 V to −1 V 96 120 dB Rev. A | Page 4 of 9 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±5 V SUPPLY 5 V SUPPLY 3 V SUPPLY ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS OUTLINE DIMENSIONS DIE SPECIFICATIONS AND ASSEMBLY RECOMMENDATIONS ORDERING GUIDE
