Datasheet LT3061 (Analog Devices) - 6
Description45V VIN, Micropower, Low Noise, 100mA LDO with Active Output Discharge
Pages / Page22 / 6 — TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. …
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. Quiescent Current. LT3061–3.3 GND Pin Current
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted Quiescent Current LT3061–3.3 GND Pin Current
LT3061 Series
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. Quiescent Current LT3061–3.3 GND Pin Current LT3061–5 GND Pin Current
120 2.50 2.50 T 110 J = 25°C VOUT = 5V 2.25 2.25 100 IL = 10µA 2.00 2.00 90 RL = 33Ω, IL = 100mA RL = 50Ω, IL = 100mA 1.75 80 1.75 70 1.50 1.50 60 1.25 1.25 50 1.00 RL = 66Ω, IL = 50mA 1.00 RL = 100Ω, IL = 50mA 40 0.75 0.75 QUIESCENT CURRENT (µA) 30 GND PIN CURRENT (mA) RL = 3.3kΩ, IL = 1mA GND PIN CURRENT (mA) RL = 5kΩ, IL = 1mA 20 0.50 0.50 RL = 330Ω, IL = 10mA RL = 500Ω, IL = 10mA 10 V 0.25 0.25 SHDN = 0V, RL = 0 0 0 0 0 5 10 15 20 25 30 35 40 45 0 1 2 3 4 5 6 7 8 9 10 11 12 0 1 2 3 4 5 6 7 8 9 10 11 12 VIN (V) VIN (V) VIN (V) 3061 G6a 3061 G06b 3061 G06
GND Pin Current VOUT = 0.6V GND Pin Current vs ILOAD SHDN Pin Threshold
2.50 4.0 1.5 RL = 6Ω, IL = 100mA VIN = VOUT(NOMINAL) +1V 1.4 2.25 RL = 12Ω, IL = 50mA 3.5 R 1.3 L = 60Ω, IL = 10mA 2.00 R 1.2 L = 600Ω, IL = 1mA 3.0 1.1 1.75 1.0 1.50 2.5 0.9 OFF TO ON 0.8 1.25 2 0.7 1.00 1.5 0.6 ON TO OFF PIN THRESHOLD (V) 0.5 0.75 GND PIN CURRENT (mA) GND PIN CURRENT (mA) 1.0 0.4 0.50 SHDN 0.3 0.2 0.25 0.5 0.1 0.00 0 0 0 1 2 3 4 5 6 7 8 9 10 0 10 20 30 40 50 60 70 80 90 100 –75 –50 –25 0 25 50 75 100 125 150 175 VIN (V) ILOAD (mA) TEMPERATURE (°C) 3061 G07 3061 G08 3061 G09
SHDN Pin Input Current SHDN Pin Input Current ADJ Pin Bias Current
3.0 3.0 50 SHDN = 45V 40 2.5 2.5 30 20 2.0 2.0 10 1.5 1.5 0 –10 1.0 1.0 PIN INPUT CURRENT (µA) PIN INPUT CURRENT (µA) –20 ADJ PIN BIAS CURRENT (nA) SHDN –30 0.5 SHDN 0.5 –40 0 0 –50 0 5 10 15 20 25 30 35 40 45 –75 –50 –25 0 25 50 75 100 125 150 175 –75 –50 –25 0 25 50 75 100 125 150 175 SHDN PIN VOLTAGE (V) TEMPERATURE (°C) TEMPERATURE (°C) 3061 G10 3061 G11 3061 G12 3061fb 6 For more information www.linear.com/LT3061
