Datasheet AD8352 (Analog Devices) - 4
Description2 GHz Ultralow Distortion Differential RF/IF Amplifier
Pages / Page19 / 4 — AD8352. Data Sheet. NOISE DISTORTION SPECIFICATIONS. Table 2. Parameter. …
RevisionC
File Format / SizePDF / 464 Kb
AD8352. Data Sheet. NOISE DISTORTION SPECIFICATIONS. Table 2. Parameter. Conditions. Min. Typ. Max. Unit
AD8352 Data Sheet NOISE DISTORTION SPECIFICATIONS Table 2 Parameter Conditions Min Typ Max Unit
link to page 11 link to page 11 link to page 11 link to page 5
VS = 5 V, RL = 200 Ω differential, RG = 118 Ω (AV = 10 dB), VOUT = 2 V p-p composite, T = 25°C; parameters specified differentially, unless otherwise noted. CD and RD are selected for differential broadband operation (see Table 5 and Table 6). See the Applications Information section for single-ended-to-differential performance characteristics.
Table 2. Parameter Conditions Min Typ Max Unit
10 MHz Second/Third Harmonic Distortion1 RL = 1 kΩ, VOUT = 2 V p-p −88/−95 dBc RL = 200 Ω, VOUT = 2 V p-p −86/−82 dBc Output Third-Order Intercept RL = 200 Ω, f1 = 9.5 MHz, f2 = 10.5 MHz 38 dBm Third-Order IMD RL = 1 kΩ, f1 = 9.5 MHz, f2 = 10.5 MHz, −86 dBc VOUT = 2 V p-p composite RL = 200 Ω, f1 = 9.5 MHz, f2 = 10.5 MHz, −81 dBc VOUT = 2 V p-p composite Noise Spectral Density (RTI) 2.7 nV/√Hz 1 dB Compression Point (RTO) 15.7 dBm 70 MHz Second/Third Harmonic Distortion RL = 1 kΩ, RG = 178 Ω, VOUT = 2 V p-p −83/−84 dBc RL = 200 Ω, RG = 115 Ω, VOUT = 2 V p-p −84/−82 dBc Output Third-Order Intercept RL = 200 Ω, f1 = 69.5 MHz, f2 = 70.5 MHz 40 dBm Third-Order IMD RL = 1 kΩ, f1 = 69.5 MHz, f2 = 70.5 MHz, −91 dBc VOUT = 2 V p-p composite RL = 200 Ω, f1 = 69.5 MHz, f2 = 70.5 MHz, −83 dBc VOUT = 2 V p-p composite Noise Spectral Density (RTI) 2.7 nV/√Hz 1 dB Compression Point (RTO) 15.7 dBm 100 MHz Second/Third Harmonic Distortion RL = 1 kΩ, VOUT = 2 V p-p −83/−83 dBc RL = 200 Ω, VOUT = 2 V p-p −84/−82 dBc Output Third-Order Intercept RL = 200 Ω, f1 = 99.5 MHz, f2 = 100.5 MHz 40 dBm Third-Order IMD RL = 1 kΩ, f1 = 99.5 MHz, f2 = 100.5 MHz, −91 dBc VOUT = 2 V p-p composite RL = 200 Ω, f1 = 99.5 MHz, f2 = 100.5 MHz, −84 dBc VOUT = 2 V p-p composite Noise Spectral Density (RTI) 2.7 nV/√Hz 1 dB Compression Point (RTO) 15.6 dBm 140 MHz Second/Third Harmonic Distortion RL = 1 kΩ, VOUT = 2 V p-p −83/−82 dBc RL = 200 Ω, VOUT = 2 V p-p −82/−84 dBc Output Third-Order Intercept RL = 200 Ω, f1 = 139.5 MHz, f2 = 140.5 MHz 41 dBm Third-Order IMD RL = 1 kΩ, f1 = 139.5 MHz, f2 = 140.5 MHz, −89 dBc VOUT = 2 V p-p composite RL = 200 Ω, f1 = 139.5 MHz, f2 = 140.5 MHz, −85 dBc VOUT = 2 V p-p composite Noise Spectral Density (RTI) 2.7 nV/√Hz 1 dB Compression Point (RTO) 15.5 dBm Rev. C | Page 4 of 19 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS NOISE DISTORTION SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION GAIN AND DISTORTION ADJUSTMENT (DIFFERENTIAL INPUT) SINGLE-ENDED INPUT OPERATION NARROW-BAND, THIRD-ORDER INTERMODULATION CANCELLATION HIGH PERFORMANCE ADC DRIVING LAYOUT AND TRANSMISSION LINE EFFECTS EVALUATION BOARD EVALUATION BOARD LOADING SCHEMES SOLDERING INFORMATION EVALUATION BOARD SCHEMATICS OUTLINE DIMENSIONS ORDERING GUIDE
