Datasheet AD8512-EP (Analog Devices)
Description | Precision, Very Low Noise, Low Input Bias Current, Wide Bandwidth JFET Dual Operational Amplifier |
Pages / Page | 7 / 1 — Precision, Very Low Noise, Low Input Bias Current,. Wide Bandwidth JFET … |
File Format / Size | PDF / 205 Kb |
Precision, Very Low Noise, Low Input Bias Current,. Wide Bandwidth JFET Operational Amplifier. Enhanced Product. AD8512-EP
Precision, Very Low Noise, Low Input Bias Current, Wide Bandwidth JFET Operational Amplifier Enhanced Product AD8512-EP FEATURES PIN CONFIGURATION Fast settling time: 500 ns to 0.1% OUT A 1 8 V+ Low offset voltage: 1.0 mV maximum at V –IN A AD8512-EP S = ±15 V 2 7 OUT B Low offset voltage drift: 1.7 µV/°C typical TOP VIEW +IN A 3 6 –IN B (Not to Scale)
002
Low input bias current: 25 pA typical at V V– 4 5 +IN B S = ±15 V
17170-
Dual-supply operation: ±5 V to ±15 V
Figure 1.
Low noise: 8.0 nV/√Hz typical at f = 1 kHz Low distortion: 0.0005% No phase reversal Unity gain stable ENHANCED PRODUCT FEATURES Supports defense and aerospace applications (AQEC standard) Military temperature range (−55°C to +125°C) Controlled manufacturing baseline 1 assembly/test site 1 fabrication site Product change notification Qualification data available on request APPLICATIONS Instrumentation Multipole filters Precision current measurement Photodiode amplifiers Military communication Avionics GENERAL DESCRIPTION
The AD8512-EP is a dual-precision JFET amplifier that features input voltages exceed the maximum common-mode voltage low offset voltage, input bias current, input voltage noise, and range. input current noise. Fast slew rate and great stability with capacitive loads make the The combination of low offsets, low noise, and very low input AD8512-EP suitable for high performance filters. Low input bias currents makes these amplifiers especially suitable for high bias currents, low offset, and low noise result in a wide dynamic impedance sensor amplification and precise current range of photodiode amplifier circuits. Low noise and distortion, measurements using shunts. The combination of dc precision, high output current, and excellent speed make the AD8512-EP low noise, and fast settling time results in superior accuracy in a great choice for military communication applications. flight instruments, electronic measurement, and aviation The AD8512-EP is available in an 8-lead narrow SOIC_N package. equipment. Unlike many competitive amplifiers, the AD8512- The AD8512-EP is specified over a military temperature range EP maintains its fast settling performance even with substantial of −55°C to +125°C. Additional application and technical capacitive loads. Unlike many older JFET amplifiers, the information can be found in the AD8512 data sheet. AD8512-EP does not suffer from output phase reversal when
Rev. 0 Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2018 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Enhanced Product Features Applications Pin Configuration General Description Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Outline Dimensions Ordering Guide
