Datasheet LTC6115 (Analog Devices) - 2
DescriptionHigh Voltage High Side Current and Voltage Sense
Pages / Page20 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION …
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION TUBE. TAPE AND REEL. PART MARKING. PACKAGE DESCRIPTION
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Note 1) ORDER INFORMATION TUBE TAPE AND REEL PART MARKING PACKAGE DESCRIPTION
LTC6115
Total Supply Voltage V+ to GND ...105V TOP VIEW V –IN 1 12 +IN S to GND ...6V NC 2 11 V+ Input Voltage (VIN Pin) ..105V OUTI 3 10 NC Minimum –IN Pin Voltage .. (V+ – 4V) GND 4 9 VIN FB 5 8 NC FB Pin Voltage .. GND – 0.3V to VS + 0.3V OUTV 6 7 VS Input Current (+IN, –IN, FB Pins) ... ±10mA MS PACKAGE Maximum Output Voltage (OUTI Pin) ..9V 12-LEAD PLASTIC MSOP θJA = 135°C/W, TJMAX = 150°C Output Short-Circuit Duration (to GND) ... Indefinite Operating Temperature Range (Note 2) LTC6115I ..–40°C to 85°C LTC6115H .. –40°C to 125°C Specified Temperature Range (Note 3) LTC6115I ..–40°C to 85°C LTC6115H .. –40°C to 125°C Storage Temperature Range .. –65°C to 150°C Lead Temperature (Soldering, 10 sec) ...300°C
ORDER INFORMATION TUBE TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LTC6115IMS#PBF LTC6115IMS#TRPBF 6115 12-Lead Plastic MSOP –40°C to 85°C LTC6115HMS#PBF LTC6115HMS#TRPBF 6115 12-Lead Plastic MSOP –40°C to 125°C
AUTOMOTIVE PRODUCTS**
LTC6115HMS#WPBF LTC6115HMS#WTRPBF 6115 12-Lead Plastic MSOP –40°C to 125°C Consult ADI Marketing for parts specified with wider operating temperature ranges. Tape and reel specifications. Some packages are available in 500 unit reels through designated sales channels with #TRMPBF suffix.
Versions of this part are available with controlled manufacturing to support the quality and reliability requirements of automotive applications. These models are designated with a #W suffix. Only the automotive grade products shown are available for use in automotive applications. Contact your local Analog Devices account representative for specific product ordering information and to obtain the specific Automotive Reliability reports for these models.
denotes the specifications which apply over the full specified temperature range, otherwise specifications are at T + A = 25°C. RIN = 100Ω, ROUT = 10kΩ, VSENSE = V+ (Note 4), 5V ≤ V+ ≤ 100V, VIN = 20V, unless otherwise noted. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS CURRENT SENSE
Supply Voltage Range (V+) l 5 100 V VOS Input Offset Voltage (+IN, –IN) VSENSE = 5mV, Gain = 100 ±85 ±500 µV l ±800 µV ∆VOS/∆T Input Offset Voltage Drift VSENSE = 5mV, Gain = 100 l ±3 µV/°C IB Input Bias Current (+IN, –IN) RIN = 1MΩ, ROUT = 1MΩ 85 170 nA l 245 nA IOS Input Offset Current RIN = 1MΩ l ±2 ±20 nA Rev. B 2 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Electrical Characteristics Pin Configuration Current Sense Typical Performance Characteristics Voltage Sense Typical Performance Characteristics Pin Functions Block Diagram Applications Information: Current Sense Applications Information: Voltage Sense Typical Applications Package Description Revision History Typical Application Related Parts
