Datasheet SM41126EL (Bourns)
ManufacturerBourns
Description10/100 Base-Tx Chip LAN Transformer Module
Pages / Page3 / 1 — *RoHS COMPLIANT. VERSIONS. AVAILABLE. Features. LEAD FREE. SM41126EL - …
File Format / SizePDF / 475 Kb
*RoHS COMPLIANT. VERSIONS. AVAILABLE. Features. LEAD FREE. SM41126EL - 10/100 Base-Tx Chip LAN Transformer Module
Datasheet SM41126EL Bourns
*RoHS COMPLIANT VERSIONS AVAILABLE Features
n IEEE 802.3 Ethernet compatible n 10/100 Mbps n Expanded temperature range: -40 to +85 °C
*RoHS COMPLIANT
n RoHS compliant*
LEAD FREE SM41126EL - 10/100 Base-Tx Chip LAN Transformer Module Electrical Specifications @ 25 °C Product Dimensions
Inductance (@ 100 kHz, 0.1 V, 8 mA) 1.27 ± 0.25 .. 350 µH min.
ARE
0.6 ± 0.10 PIN 1 POINT (.050 ± .010) 1.00 ± 0.25 (.024 ± .004) (.039 ± .010) Insertion Loss (TD-MX)
LEAD FREE
1-100 MHz ...-1.2 dB max.
VERSIONS
S
RoHS COMPLIANT*
Return Loss (TD-MX) Y M Y 4 1-30 MHz ...-18 dB min. WW 11 12.7 ± 0.25 40 MHz ...-15.5 dB min. 26 (.500 ± .010) 8.89 ± 0.25 50 MHz ...-13.5 dB min. L (.350 ± .010) 60-80 MHz ...-10 dB min. DCMRR (TD to TX)
APPROVED
7.2 ± 0.25 0.8 ± 0.05 1-60 MHz ...-33 dB min.
*RoHS COMPLIANT & AEC
(.283 ± .010) (.031 ± .002) DIMENSIONS: MM 60-100 MHz ...-26 dB min. 8.67 ± 0.25 (INCHES) (.341 ± .010) 4.0 ± 0.25 Cross Talk (between each channel) (.157 ± .010) 1-100 MHz ...-38 dB min. Hi-Pot Test .. 1500 Vac, 60 s
Electrical Schematic
Operating Temperature .-40 °C to +85 °C Storage Temperature ..-40 °C to +85 °C TD+ 1 16
, **HALOGEN FREE
TX+ Pin 1 Point Moisture Sensitivity Level ...1 TD+ TX+ ESD Classification (HBM)... N/A TCT 2 15 TCT TCT TCT TD- TX- TD- 3
14
AEC COMPLIANT
TX- NC NC
Packaging Specifications
RD+ 6
*RoHS COMPLIANT
NC NC 11 RX+ RD+ RX+
*RoHS and
Tape & Reel ... 800 pcs./reel RCT 7 10 RCT RCT RCT RD- RX-
AEC-Q200 COMPLIANT How To Order
RD- 8 9 RX-
*RoHS COMPLIANT and **HALOGEN FREE SM41126 E L
Model
Solder Profile
Packaging E = Tape and Reel Preheating Soldering Natural Cooling Termination TP (260 °C / 10 Sec. Max.) L = Tin finish (RoHS Compliant) tp (245 °C, 20~40 Sec.)
Recommended Layout
217 °C 0.64 ± 0.05 200 °C (.025 ± .002) 1.27 ± 0.05 60~150 Sec. 150°C (.050 ± .002) Temperature (°C) 60~180 Sec. 8.89 ± 0.25 480 Sec. Max. 25 (.350 ± .010) Time (Seconds) Reflow Times: 3 Times Max. 6.86 ± 0.25 (.270 ± .010) 10.67 ± 0.25 (.420 ± .010)
WARNING Cancer and Reproductive Harm -
www.P65Warnings.ca.gov *RoHS Directive 2015/863, Mar 31, 2015 and Annex. Specifications are subject to change without notice. Users should verify actual device performance in their specific applications. The products described herein and this document are subject to specific legal disclaimers as set forth on the last page of this document, and at www.bourns.com/docs/legal/disclaimer.pdf.
