Datasheet HMC1020LP4E (Analog Devices) - 5
DescriptionRMS Power Detector SMT, Single-Ended, DC - 3.9 GHz
Pages / Page24 / 5 — HMC1020LP4E. RMS POWER DETECTOR. SINGLE-ENDED, DC - 3.9 GHz. Electrical …
HMC1020LP4E. RMS POWER DETECTOR. SINGLE-ENDED, DC - 3.9 GHz. Electrical Specifications III. Single-Ended Input Configuration
HMC1020LP4E RMS POWER DETECTOR SINGLE-ENDED, DC - 3.9 GHz Electrical Specifications III Single-Ended Input Configuration
HMC1020LP4E
v02.0511
TA = +25 °C, Vcc = 5V, Sci4 = Sci1 = 0V, Sci3 = Sci2 = 5V, Unless Otherwise Noted Parameter conditions Min typ. Max Units
Input Network return Loss up to 3.9 GHz > 15 dB Input resistance between INP and INN Between pins 3 and 4 100 Ω Input Voltage range Ac coupled peak voltage at INP 0.85 V
RMSOUT Output
output Voltage range 0.13 to 2.7 V source/sink current compliance rMsoUt held at Vcc/2 8 / -0.55 mA 11 Output Slew Rate (rise / fall) sci4=sci3=sci2=sci1=0V, cofs=1nF 24 / 1.9 106 V/s
VSET Input (Negative Feedback Terminal)
For control applications with nominal Input Voltage range 0.13 to 2.7 V slope/intercept settings t Input resistance 5 MΩ M
SCI1-4 Inputs, ENX Logic Input (Power Down Control)
Input High Voltage 0.7xVcc V s Input Low Voltage 0.3xVcc V - Input High current 1 μA Input Low current 1 μA rs Input capacitance 0.5 pf o
Power Supply
t supply Voltage 4.5 5 5.5 V c supply current with no input power 55 mA e t supply current with Pin = -20dBm 58 mA e standby Mode supply current 5 mA D r e w o P For price, delivery and to place orders: Hittite Microwave Corporation, 20 Alpha Road, Chelmsford, MA 01824 Phone: 978-250-3343 Fax: 978-250-3373 Order On-line at www.hittite.com
11 - 3
Application Support: Phone: 978-250-3343 or apps@hittite.com Document Outline Typical Applications Features Functional Diagram General Descriptions Electrical Specifications I Electrical Specifications II RMSOUT vs. Pin with Different Modulations @ 1900 MHz RMSOUT Error vs. Pin with Different Modulations @ 1900 MHz Electrical Specifications III Typical Performance Characteristics RMSOUT & Error vs. Pin @ 100 MHz RMSOUT & Error vs. Pin @ 900 MHz RMSOUT & Error vs. Pin @ 1900 MHz RMSOUT & Error vs. Pin @ 2200 MHz RMSOUT & Error vs. Pin @ 2700 MHz RMSOUT & Error vs. Pin @ 3500 MHz RMSOUT & Error vs. Pin @ 3900 MHz Intercept vs. Frequency Slope vs. Frequency RMSOUT vs. Pin with WCDMA 4 Carrier @ +25 °C RMSOUT Error vs. Pin with WCDMA 4 Carrier @ +25 °C RMSOUT Error vs. Pin with WCDMA 4 Carrier @ +85 °C wrt +25 °C Response RMSOUT Error vs. Pin with WCDMA 4 Carrier @ -40 °C wrt +25 °C Response RMSOUT vs. Pin with CW @ +25 °C RMSOUT Error vs. Pin with CW @ +25 °C RMSOUT vs. Pin w/ CW & WCDMA 4 Carrier @ 1900 MHz & +25 °C Reading Error for WCDMA 4 Carrier wrt CW Response @ +25 °C RMSOUT vs. Pin w/ CW & WCDMA 4 Carrier @ 1900 MHz & +85 °C Reading Error for WCDMA 4 Carrier wrt CW Response @ +85 °C RMSOUT vs. Pin w/ CW & WCDMA 4 Carrier @ 1900 MHz & -40 °C Reading Error for WCDMA 4 Carrier wrt CW Response @ -40 °C Output Response with SCI = 0000 @ 1900 MHz Output Response with SCI = 1100 @ 1900 MHz Typical Supply Current vs. Pin, Vcc = 5V Input Return Loss vs. Frequency Output Ripple & Rise/Fall Time vs. Integration Setting [Sci4,Sci3,Sci2,Sci1] in Decimal Absolute Maximum Ratings Outline Drawing Package Information Pin Descriptions Evaluation PCB List of Materials Evaluation Order Information Application Circuit Application Information Principle of Operation Configuration For The Typical Application Broadband Single-Ended Input Interface RMSOUT & Error vs. Pin RMS Output Interface and Transient Response Table 1: Transient Response vs. SCI Setting Rise Time vs. SCI Setting over Input Power Rise Settling Time vs. SCI Setting over Input Power Fall Time vs. SCI Setting over Input Power Residual Ripple for 900 Mhz WiMAX @ SCI=0100 Residual Ripple for 900 Mhz WiMAX @ SCI=0110 Residual Ripple for 900 Mhz WiBRO @ SCI=0100 Residual Ripple for 900 Mhz WiBRO @ SCI=0110 Residual Ripple for 900 Mhz LTE Downlink @ SCI=0100 Residual Ripple for 900 Mhz LTE Downlink @ SCI=0110 Residual Ripple for 900 Mhz WCDMA4 @ SCI=0011 Residual Ripple for 900 Mhz WCDMA4 @ SCI=0100 LOG-Slope and Intercept Slope Adjustment Intercept Adjustment DC Offset Compensation Loop Standby Mode Modulation Performance - Crest factor performance Reading Error for WCDMA 4 Carrier wrt CW Response @ +25 °C Reading Error for WCDMA 4 Carrier wrt CW Response @ 2200MHz RMSOUT Error vs. Crest Factor over Frequency System Calibration Layout Considerations Definitions
