HMC713MS8 / 713MS8E v06.0412 54 DB, LOGARITHMICDETECTOR / CONTROLLER, 45 - 2700 MHzEvaluation PCB t M s - rs o t c e t e D r e w o P List of Materials for Evaluation PCB 121947 [1] Item Description the circuit board used in the application should use rF circuit design techniques. signal lines J1 - J3 Pc Mount sMA connector should have 50 ohm impedance while the package J5 - J7 Dc Pin ground leads and exposed paddle should be con- c3 1 pF capacitor, 0402 Pkg. nected directly to the ground plane similar to that c6 0.1 µF capacitor, 0402 Pkg. shown. A sufficient number of via holes should be r1, r7, r10 0Ω resistor, 0402 Pkg. used to connect the top and bottom ground planes. r2 51Ω resistor, 0402 Pkg. the evaluation circuit board shown is available from r3, r5 10k resistor, 0402 Pkg. Hittite upon request. r6 1k resistor, 0402 Pkg. HMc713Ms8(e) U1 Logarithmic Detector / controller PcB [2] 121944 evaluation PcB [1] reference this number when ordering complete evaluation PcB [2] circuit Board Material: Arlon 25Fr or rogers 4350 I F nf o or r p mati r o in cfe ur , d nish e e l d iv b e y r A y a nalo n g d t Devi o p ces i la s c bele o ieve rd d t e o rbs e : H acc iutrtatite e M and ic reli rao bl w e. a H v o e C wever o , nrp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No rd Phoe n r O e: 7 n- 81-li 3 n 2 e a 9-4 t w 70 ww 0 • O . rdh e itt r o it nle i . n co e a m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. t www.analog.com 10 Application Support: Phon Trademarks and registered trademarks are the property of their respective owners. e: 978-250-334 A 3 o pplic r a atio pp n S s u @ p h por ittti : Pte. ho c n o e m : 1-800-ANALOG-D
