Datasheet HMC602LP4, 602LP4E (Analog Devices) - 4
Description70 dB, LOGARITHMIC DETECTOR / CONTROLLER, 1 - 8000 MHz
Pages / Page8 / 4 — HMC602LP4 / 602LP4E. 70 dB, LOGARITHMIC. DETECTOR / CONTROLLER, 1 - 8000 …
File Format / SizePDF / 540 Kb
HMC602LP4 / 602LP4E. 70 dB, LOGARITHMIC. DETECTOR / CONTROLLER, 1 - 8000 MHz. LOGOUT Slope vs. Frequency
HMC602LP4 / 602LP4E 70 dB, LOGARITHMIC DETECTOR / CONTROLLER, 1 - 8000 MHz LOGOUT Slope vs Frequency
HMC602LP4 / 602LP4E
v03.0209
70 dB, LOGARITHMIC DETECTOR / CONTROLLER, 1 - 8000 MHz LOGOUT Slope vs. Frequency LOGOUT Slope vs. Supply Voltage
-20 -20 0.1GHz -22 -22 1.9GHz 3.6GHz 5.8GHz 8GHz -24 -24 -26 -26 SLOPE (mV/dB) -28 -28 SLOPE (mV/dB) +25C +85C -30 -40C -30 -32 -32 0 1 2 3 4 5 6 7 8 12 4.5 5 5.5 FREQUENCY (GHz) Vcc1, Vcc2, Vcc3 (Volts) T
LOGOUT Intercept vs. Frequency LOGOUT Intercept vs. Supply Voltage
30 26 24 S - SM 27 R 22 24 O 20 T 21 C 18 E 18 INTERCEPT (dBm) +25C INTERCEPT (dBm) 16 0.1GHz T +85C 1.9GHz -40C 3.6GHz 15 5.8GHz E 14 8GHz 12 12 0 1 2 3 4 5 6 7 8 4.5 5 5.5 R D FREQUENCY (GHz) Vcc1, Vcc2, Vcc3 (Volts) E W
LOGOUT Error vs. Input Power, LOGOUT Voltage
O
Normalized [2], Fin= 1900 MHz vs. Input Power & Frequency
P 2 2.4 2 1 1.6 0 1.2 50 MHz 100 MHz LOGOUT (V) 900 MHz 0.8 1900 MHz -1 +85C 2200 MHz -40C 0.4 3600MHz RELATIVE ERROR TO 25C (dB) 5800MHz 8000MHz -2 0 -70 -60 -50 -40 -30 -20 -10 0 10 -70 -60 -50 -40 -30 -20 -10 0 10 INPUT POWER (dBm) INPUT POWER (dBm) [1] Unless otherwise noted: Vcc1, Vcc2, Vcc3 = +5V, TA = +25C [2] This data is relative to the room temperature performance of the HMC602LP4(E) [3] Reference plane at J1 connector on Evaluation PCB Information furnis F heod r pri by An ce, de alog Devi lcievs eir s y b , a eliev nd to pla ed to be accu ce o rate anrder d relia sbl, pl e. H ease co owever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone: 978 rights of third parties that may result from its use. Specifications subject to change without notice. No Ph - o 25 ne 0 : 7 -3 81- 3 3 4 29 3 F -470 ax: 978 0 • Orde - r o 25 nlin 0- e a3 t 373 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
12 - 21
Order On-l Trademarks and registered trademarks are the property of their respective owners. ine at www.hit A ti p te.co plicati m on Support: Phone: 1-800-ANALOG-D
