Datasheet AD8275 (Analog Devices) - 3
DescriptionG = 0.2, Level Translation, 16-Bit ADC Driver
Pages / Page16 / 3 — Data Sheet. AD8275. SPECIFICATIONS. Table 2. A Grade. B Grade. Parameter. …
File Format / SizePDF / 541 Kb
Data Sheet. AD8275. SPECIFICATIONS. Table 2. A Grade. B Grade. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
Data Sheet AD8275 SPECIFICATIONS Table 2 A Grade B Grade Parameter Test Conditions/Comments Min Typ Max Unit
link to page 6 link to page 4 link to page 4 link to page 7 link to page 12 link to page 6 link to page 4 link to page 9 link to page 9
VS = 5 V, G = 0.2, REF1 connected to GND and REF2 connected to 5 V, RL = 2 kΩ connected to VS/2, TA = 25°C, unless otherwise noted. Specifications referred to output unless otherwise noted.
Table 2. A Grade B Grade Parameter Test Conditions/Comments Min Typ Max Min Typ Max Unit
DYNAMIC PERFORMANCE Small Signal Bandwidth −3 dB 10 15 10 15 MHz Slew Rate 4 V step 20 25 20 25 V/µs Settling Time to 0.01% 4 V step on output, CL = 100 pF 350 350 450 ns Settling Time to 0.001% 4 V step on output, CL = 100 pF 450 450 550 ns Overload Recovery Time 50% overdrive 300 300 ns NOISE/DISTORTION1 THD + N f = 1 kHz, VOUT = 4 V p-p, 22 kHz band 106 106 dB pass filter Voltage Noise f = 0.1 Hz to 10 Hz, referred to output 1 4 1 4 µV p-p Spectral Noise Density f = 1 kHz, referred to output 40 40 nV/√Hz GAIN VREF2 = 4.096 V, REF1 and RL connected 0.2 0.2 V/V to GND, (VIN+) − (VIN−) = −10 V to +10 V Gain Error 0.024 0.024 % Gain Drift −40°C to +85°C 1 3 0.3 1 ppm/°C Gain Nonlinearity VOUT = 4 V p-p, RL = 600 Ω, 2 kΩ, 10 kΩ 2.5 2.5 3 ppm OFFSET AND CMRR Offset2 Referred to output, VS = ±2.5 V, 300 700 150 500 µV reference and input pins grounded vs. Temperature −40°C to +85°C 2.5 2.5 7 µV/°C vs. Power Supply VS = 3.3 V to 5 V 90 100 dB Reference Divider Accuracy 0.024 0.024 % Common-Mode Rejection VCM = ±10 V, referred to output 80 96 86 dB Ratio3 INPUT CHARACTERISTICS Input Voltage Range4 −12.3 +12 −12.3 +12 V Impedance5 Differential VCM = VS/2 108||2 108||2 kΩ||pF Common Mode 27.5||2 27.5||2 kΩ||pF OUTPUT CHARACTERISTICS Output Swing VREF2 = 4.096 V, REF1 and RL connected −VS + +VS − −VS + +VS − V to GND, RL = 2 kΩ 0.048 0.1 0.048 0.1 Capacitive Load6 100 100 pF Short-Circuit Current Limit 30 30 mA POWER SUPPLY Specified Voltage Range 5 5 V Operating Voltage Range 3.3 15 3.3 15 V Supply Current IO = 0 mA, VS = ±2.5 V, reference and 1.9 2.3 1.9 2.3 mA input pins grounded Over Temperature IO = 0 mA, VS = ±2.5 V, reference and 2.1 2.7 2.1 2.7 mA input pins grounded, −40°C to +85°C TEMPERATURE RANGE Specified Performance −40 +85 −40 +85 °C 1 Includes amplifier voltage and current noise, as well as noise of internal resistors. 2 Includes input bias and offset current errors. 3 See Figure 7 for CMRR vs. temperature. 4 The input voltage range is a function of the voltage supplies, reference voltage, and ESD diodes. When operating on other supply voltages, see the Absolute Maximum Ratings section, Figure 11, and Table 5 for more information. 5 Internal resistors are trimmed to be ratio matched but have ±20% absolute accuracy. 6 See Figure 25 to Figure 28 in the Typical Performance Characteristics section for more information. Rev. B | Page 3 of 16 Document Outline Features Applications Pin Configuration Typical Application General Description Revision History Specifications Absolute Maximum Ratings Maximum Power Dissipation ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Basic Connection Power Supplies Reference Common-Mode Input Voltage Range Input Protection Configurations Applications Information Driving a Single-Ended ADC Differential Outputs Increasing Input Impedance AC Coupling Using the AD8275 as a Level Translator in a Data Acquisition System Outline Dimensions Ordering Guide
