Datasheet MAX5035 (Maxim) - 5
Manufacturer | Maxim |
Description | 1A, 76V, High-Efficiency MAXPower Step-Down DC-DC Converter |
Pages / Page | 17 / 5 — 1A, 76V, High-Efficiency MAXPower. Step-Down DC-DC Converter. ELECTRICAL … |
File Format / Size | PDF / 553 Kb |
1A, 76V, High-Efficiency MAXPower. Step-Down DC-DC Converter. ELECTRICAL CHARACTERISTICS (MAX5035_A_ _) (continued)
MAX5035
1A, 76V, High-Efficiency MAXPower Step-Down DC-DC Converter ELECTRICAL CHARACTERISTICS (MAX5035_A_ _) (continued)
(VIN = +12V, VON/OFF = +12V, IOUT = 0,
TA = TJ = -40°C to +125°C
, unless otherwise noted. Typical values are at TA = +25°C. See the Typical Application Circuit.) (Note 2)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS PACKAGE THERMAL CHARACTERISTICS
Thermal Resistance SO package (JEDEC 51) 170 θJA °C/W (Junction to Ambient) DIP package (JEDEC 51) 110
THERMAL SHUTDOWN
Thermal-Shutdown Junction T Temperature SH +160 °C Thermal-Shutdown Hysteresis THYST 20 °C
Note 1:
Switch current at which current limit is activated.
Note 2:
All limits at -40°C are guaranteed by design, not production tested.
Typical Operating Characteristics
(VIN = 12V, VON/OFF = 12V, TA = -40°C to +125°C, unless otherwise noted. Typical values are at TA = +25°C. See the Typical Application Circuit, if applicable.)
VOUT vs. TEMPERATURE VOUT vs. TEMPERATURE LINE REGULATION (MAX5035AASA, VOUT = 3.3V) (MAX5035DASA, VOUT = 5V) (MAX5035AASA, VOUT = 3.3V)
3.40 5.20 3.40 IOUT = 0.1A IOUT = 0.1A 5.15 MAX5035 toc01 3.36 MAX5035 toc02 MAX5035 toc03 3.36 5.10 I I OUT = 1A OUT = 1A I 3.32 5.05 OUT = 0.1A 3.32 (V) (V) 5.00 V OUT V OUT 3.28 3.28 4.95 IOUT = 1A OUTPUT VOLTAGE (V) 4.90 3.24 3.24 4.85 3.20 4.80 3.20 -50 -25 0 25 50 75 100 125 150 -50 -25 0 25 50 75 100 125 150 5 20 35 50 65 80 TEMPERATURE (°C) TEMPERATURE (°C) INPUT VOLTAGE (V)
LINE REGULATION LOAD REGULATION LOAD REGULATION (MAX5035DASA, VOUT = 5V) (MAX5035AASA, VOUT = 3.3V) (MAX5035DASA, VOUT = 5V)
5.20 3.40 5.10 VIN = 76V 5.15 MAX5035 toc04 MAX5035 toc05 3.36 MAX5035 toc06 5.10 5.05 VIN = 7.5V, 24V VIN = 24V 5.05 IOUT = 0.1A 3.32 V (V) (V) IN = 7.5V 5.00 5.00 V OUT V OUT 3.28 4.95 IOUT = 1A V OUTPUT VOLTAGE (V) IN = 76V 4.90 4.95 3.24 4.85 4.80 3.20 4.90 5 20 35 50 65 80 0 200 400 600 800 1000 0 200 400 600 800 1000 INPUT VOLTAGE (V) ILOAD (mA) ILOAD (mA) Maxim Integrated 5
