Datasheet OP07D (Analog Devices)
Description | Ultralow Offset Voltage Operational Amplifier |
Pages / Page | 17 / 1 — 150 μV Maximum Offset Voltage Op Amp. OP07D. FEATURES. PIN … |
Revision | A |
File Format / Size | PDF / 242 Kb |
150 μV Maximum Offset Voltage Op Amp. OP07D. FEATURES. PIN CONFIGURATIONS. Low offset voltage: 150 µV max. NULL
150 μV Maximum Offset Voltage Op Amp OP07D FEATURES PIN CONFIGURATIONS Low offset voltage: 150 µV max NULL 1 8 NULL Input offset drift: 1.5 µV/°C max –IN 2 OP07D 7 V+ Low noise: 0.25 μV p-p TOP VIEW +IN 3 6 OUT (Not to Scale) High gain CMRR and PSRR: 115 dB min V– 4 5 NC
001
Low supply current: 1.1 mA NC = NO CONNECT
05867-
Wide supply voltage range: ±4 V to ±18 V operation
Figure 1. 8-Lead SOIC_N (R-8), 8-Lead DIP (N-8)
APPLICATIONS Medical and industrial instrumentation Sensors and controls Thermocouple RTDs Strain bridges Shunt current measurements Precision filters GENERAL DESCRIPTION
The OP07D is a precision, ultralow offset amplifier. It integrates low power (1.1 mA typical), low input bias current (±1 nA maximum), and high CMRR/PSRR (130 dB) in the small DIP package. Operation is ful y specified from ±5 V to ±15 V supply. The OP07D provides higher accuracy than industry-standard OP07-type amplifiers due to Analog Devices’ iPolar™ process, which supports enhanced performance in a smal er footprint. These performance enhancements include wider output swing, lower power, and higher CMRR (common-mode rejection ratio) and PSRR (power supply rejection ratio). The OP07D maintains stability of offsets and gain virtually regardless of variations in time or temperature. Excel ent linearity and gain accuracy can be maintained at high closed-loop gains. The OP07D is fully specified over the extended industrial tem- perature range of −40°C to +125°C. The OP07D amplifier is available in 8-lead DIP and the popular 8-lead, narrow SOIC lead-free packages.
Rev. A Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 © 2005–2011 Analog Devices, Inc. All rights reserved.
Document Outline Features Applications General Description Pin Configurations Revision History Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Outline Dimensions Ordering Guide
