Enhanced ProductADA4528-2-EPELECTRICAL CHARACTERISTICS—5 V OPERATION VSY = 5 V, VCM = VSY/2, TA = 25°C, unless otherwise specified. Table 2. ParameterSymbolTest Conditions/CommentsMinTypMaxUnit INPUT CHARACTERISTICS Offset Voltage VOS VCM = 0 V to 5 V 0.3 2.5 μV −55°C ≤ TA ≤ +125°C 4 μV Offset Voltage Drift ΔVOS/ΔT −55°C ≤ TA ≤ +125°C 0.002 0.015 μV/°C Input Bias Current IB 125 250 pA −55°C ≤ TA ≤ +125°C 400 pA Input Offset Current IOS 250 500 pA −55°C ≤ TA ≤ +125°C 650 pA Input Voltage Range 0 5 V Common-Mode Rejection Ratio CMRR VCM = 0 V to 5 V 137 160 dB −55°C ≤ TA ≤ +125°C 122 dB Open-Loop Gain AVO RL = 10 kΩ, VO = 0.1 V to 4.9 V 127 139 dB −55°C ≤ TA ≤ +125°C 125 dB RL = 2 kΩ, VO = 0.1 V to 4.9 V 121 131 dB −55°C ≤ TA ≤ +125°C 120 dB Input Resistance Differential Mode RINDM 190 kΩ Common Mode RINCM 1 GΩ Input Capacitance Differential Mode CINDM 16.5 pF Common Mode CINCM 33 pF OUTPUT CHARACTERISTICS Output Voltage High VOH RL = 10 kΩ to VCM 4.99 4.995 V −55°C ≤ TA ≤ +125°C 4.98 V RL = 2 kΩ to VCM 4.96 4.98 V −55°C ≤ TA ≤ +125°C 4.94 V Output Voltage Low VOL RL = 10 kΩ to VCM 5 10 mV −55°C ≤ TA ≤ +125°C 20 mV RL = 2 kΩ to VCM 20 40 mV −55°C ≤ TA ≤ +125°C 60 mV Short-Circuit Current ISC ±40 mA Closed-Loop Output Impedance ZOUT f = 1 kHz, AV = +10 0.1 Ω POWER SUPPLY Power Supply Rejection Ratio PSRR VSY = 2.2 V to 5.5 V 130 150 dB −55°C ≤ TA ≤ +125°C 127 dB Supply Current per Amplifier ISY IO = 0 mA 1.5 1.8 mA −55°C ≤ TA ≤ +125°C 2.2 mA DYNAMIC PERFORMANCE Slew Rate SR RL = 10 kΩ, CL = 100 pF, AV = +1 0.5 V/μs Settling Time to 0.1% tS VIN = 4 V step, RL = 10 kΩ, CL = 100 pF, AV = −1 10 µs Unity-Gain Crossover UGC VIN = 10 mV p-p, RL = 10 kΩ, CL = 100 pF, AV = +1 4 MHz Phase Margin ΦM VIN = 10 mV p-p, RL = 10 kΩ, CL = 100 pF, AV = +1 57 Degrees Gain Bandwidth Product GBP VIN = 10 mV p-p, RL = 10 kΩ, CL = 100 pF, AV = +100 3.4 MHz −3 dB Closed-Loop Bandwidth f−3dB VIN = 10 mV p-p, RL = 10 kΩ, CL = 100 pF, AV = +1 6.5 MHz Overload Recovery Time RL = 10 kΩ, CL = 100 pF, AV = −10 50 μs NOISE PERFORMANCE Voltage Noise en p-p f = 0.1 Hz to 10 Hz, AV = +100 99 nV p-p Voltage Noise Density en f = 1 kHz, AV = +100 5.9 nV/√Hz f = 1 kHz, AV = +100, VCM = 4.5 V 5.3 nV/√Hz Current Noise in p-p f = 0.1 Hz to 10 Hz, AV = +100 10 pA p-p Current Noise Density in f = 1 kHz, AV = +100 0.5 pA/√Hz Rev. 0 | Page 5 of 17 Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS PIN CONNECTION DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—2.5 V OPERATION ELECTRICAL CHARACTERISTICS—5 V OPERATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
