Datasheet ADA4528-2-EP (Analog Devices) - 6
DescriptionPrecision, Ultralow Noise, RRIO, Zero-Drift Dual Op Amp
Pages / Page17 / 6 — ADA4528-2-EP. Enhanced Product. ABSOLUTE MAXIMUM RATINGS Table 3. THERMAL …
File Format / SizePDF / 661 Kb
ADA4528-2-EP. Enhanced Product. ABSOLUTE MAXIMUM RATINGS Table 3. THERMAL RESISTANCE. Parameter. Rating
ADA4528-2-EP Enhanced Product ABSOLUTE MAXIMUM RATINGS Table 3 THERMAL RESISTANCE Parameter Rating
ADA4528-2-EP Enhanced Product ABSOLUTE MAXIMUM RATINGS Table 3. THERMAL RESISTANCE Parameter Rating
Thermal performance is directly linked to printed circuit board Supply Voltage 6 V (PCB) design and operating environment. Input Voltage ±V ± 0.3 V SY Careful attention to PCB thermal design is required. Input Current1 ±10 mA Differential Input Voltage ±V θ SY JA is the natural convection junction to ambient thermal resistance Output Short-Circuit Duration to GND Indefinite measured in a one cubic foot sealed enclosure (still air). Storage Temperature Range −65°C to +150°C θJC is the junction to case thermal resistance, measured on the Operating Temperature Range −55°C to +125°C exposed pad of the package. Junction Temperature Range −65°C to +150°C Lead Temperature (Soldering, 60 sec) 300°C
Table 4. Thermal Resistance Package Type θ θ Unit JA JC
1 The input pins have clamp diodes to the power supply pins. Limit the input CP-8-191 52 3.9 °C/W current to 10 mA or less whenever input signals exceed the power supply rail by 0.3 V. 1 Thermal reporting per JEDEC JESD51-12. Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a
ESD CAUTION
stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. 0 | Page 6 of 17 Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS PIN CONNECTION DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—2.5 V OPERATION ELECTRICAL CHARACTERISTICS—5 V OPERATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS OUTLINE DIMENSIONS ORDERING GUIDE
