Datasheet LT5538 (Analog Devices) - 3
Description40MHz to 3.8GHz RF Power Detector with 75dB Dynamic Range
Pages / Page12 / 3 — ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply …
File Format / SizePDF / 241 Kb
ELECTRICAL CHARACTERISTICS. The. denotes the specifi cations which apply over the full operating
ELECTRICAL CHARACTERISTICS The denotes the specifi cations which apply over the full operating
LT5538
denotes the specifi cations which apply over the full operating temperature range, otherwise specifi cations are at TA = 25°C, VCC = 5V, ENBL = 5V. (Note 2) SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
2nd Order Harmonic Distortion Pin = –10dBm; At RF Input –62 dBc 3rd Order Harmonic Distortion Pin = –10dBm; At RF Input –61 dBc
fRF = 450 MHz
RF Input Power Range –75 to 10 dBm Linear Dynamic Range ±1 dB Linearity Error (Note 3) 75 dB Output Slope 19.6 mV/dB Logarithmic Intercept (Note 5) –87.3 dBm Sensitivity –71.5 dBm Output Variation vs Temperature Normalized to Output at 25°C PIN = –50dBm; –40°C < TA < 85°C ● 0.1/0.6 dB PIN = –30dBm; –40°C < TA < 85°C ● 0.1/0.5 dB PIN = –10dBm; –40°C < TA < 85°C ● –0.1/0.5 dB 2nd Order Harmonic Distortion Pin = –10dBm; At RF Input –43 dBc 3rd Order Harmonic Distortion Pin = –10dBm; At RF Input –44 dBc
fRF = 880 MHz
RF Input Power Range –75 to 10 dBm Linear Dynamic Range ±1 dB Linearity Error (Note 3) 75 dB Output Slope 19.0 mV/dB Logarithmic Intercept (Note 5) –88.8 dBm Sensitivity –71.5 dBm Output Variation vs Temperature Normalized to Output at 25°C PIN = –50dBm; –40°C < TA < 85°C ● 0.1/0.7 dB PIN = –30dBm; –40°C < TA < 85°C ● 0.1/0.4 dB PIN = –10dBm; –40°C < TA < 85°C ● 0.1/0.4 dB 2nd Order Harmonic Distortion Pin = –10dBm; At RF Input –37 dBc 3rd Order Harmonic Distortion Pin = –10dBm; At RF Input –40 dBc
fRF = 2140 MHz
RF Input Power Range –72 to 10 dBm Linear Dynamic Range ±1 dB Linearity Error (Note 3) 70 dB Output Slope 17.7 mV/dB Logarithmic Intercept (Note 5) –89.0 dBm Sensitivity –69.0 dBm Output Variation vs Temperature Normalized to Output at 25°C PIN = –50dBm; –40°C < TA < 85°C ● 0.3/0.4 dB PIN = –30dBm; –40°C < TA < 85°C ● 0.4/0.1 dB PIN = –10dBm; –40°C < TA < 85°C ● 0.7/0.5 dB
fRF = 2700 MHz
RF Input Power Range –72 to 10 dBm Linear Dynamic Range ±1 dB Linearity Error (Note 3) 65 dB Output Slope 17.6 mV/dB Logarithmic Intercept (Note 5) –87.5 dBm 5538f 3
