LT5538 ELECTRICAL CHARACTERISTICSThe ● denotes the specifi cations which apply over the full operatingtemperature range, otherwise specifi cations are at TA = 25°C, VCC = 5V, ENBL = 5V. (Note 2)SYMBOLPARAMETERCONDITIONSMINTYPMAXUNITS Sensitivity –69.5 dBm Output Variation vs Temperature Normalized to Output at 25°C PIN = –50dBm; –40°C < TA < 85°C ● 0.3/0.3 dB PIN = –30dBm; –40°C < TA < 85°C ● 0.7/–0.3 dB PIN = –10dBm; –40°C < TA < 85°C ● 1.1/–0.9 dB fRF = 3600 MHz RF Input Power Range –65 to 10 dBm Linear Dynamic Range ±1 dB Linearity Error (Note 3) 57 dB Output Slope 18 mV/dB Logarithmic Intercept (Note 5) –81.4 dBm Sensitivity –63 dBm Output Variation vs Temperature Normalized to Output at 25°C PIN = –45dBm; –40°C < TA < 85°C ● 0.6/–0.3 dB PIN = –25dBm; –40°C < TA < 85°C ● 0.9/–0.6 dB PIN = –5dBm; –40°C < TA < 85°C ● 1.4/–1.2 dB Output Interface Output DC Voltage No RF Signal Present 0.350 V Output Impedance 150 Ω Source Current 10 mA Sink Current 200 μA Rise Time 0.5V to 1.6V, 10% to 90%, fRF = 880 MHz 100 ns Fall Time 1.6V to 0.5V, 10% to 90%, fRF = 880 MHz 180 ns Power Up/Down ENBL = High (On) ● 1 V ENBL = Low (Off) ● 0.3 V ENBL Input Current VENBL = 5V 205 μA Turn ON time 300 ns Turn OFF Time 1 μs Power Supply Supply Voltage 3 5.25 V Supply Current 29 36 mA Shutdown Current ENBL = Low 1 100 μA Note 1: Stresses beyond those listed under Absolute Maximum Ratings to –20dBm. The dynamic range is defi ned as the range over which the may cause permanent damage to the device. Exposure to any Absolute linearity error is within ±1dB. Maximum Rating condition for extended periods may affect device Note 4: Sensitivity is defi ned as the minimum input power required for the reliability and lifetime. linearity error within 3dB of the ideal log-linear transfer curve. Note 2: Specifi cations over the –40°C to 85°C temperature range are Note 5: Logarithmic Intercept is an extrapolated input power level from the assured by design, characterization and correlation with statistical process best-fi tted log-linear straight line, where the output voltage is 0V. control. Note 3: The linearity error is calculated by the difference between the incremental slope of the output and the average slope from –50dBm 5538f 4
