2N3019, 2N3019S, 2N3700PACKAGE DIMENSIONSTO−5 3−Lead CASE 205AA ISSUE B B NOTES: 1. DIMENSIONING AND TOLERANCING PER ASME Y14.5M, 1994. ADETAIL X 2. CONTROLLING DIMENSION: INCHES. B 3. DIMENSION J MEASURED FROM DIAMETER A TO EDGE. 4. LEAD TRUE POSITION TO BE DETERMINED AT THE GUAGE UPC PLANE DEFINED BY DIMENSION R. 5. DIMENSION F APPLIES BETWEEN DIMENSION P AND L. U 6. DIMENSION D APPLIES BETWEEN DIMENSION L AND K. 7. BODY CONTOUR OPTIONAL WITHIN ZONE DEFINED BY DIMEN LSEATING SIONS A, B, AND T. RA PLANEF 8. DIMENSION B SHALL NOT VARY MORE THAN 0.010 IN ZONE P. KNOTE 5MILLIMETERSINCHESDIMMINMAXMINMAXEA 8.89 9.40 0.350 0.370 TB 8.00 8.51 0.315 0.335 NOTE 7C 6.10 6.60 0.240 0.260 DETAIL X3XDD 0.41 0.53 0.016 0.021 NOTES 4 & 6E 0.23 3.18 0.009 0.125 0.007 (0.18MM) A B S C M F 0.41 0.48 0.016 0.019 H 0.71 0.86 0.028 0.034 J 0.73 1.02 0.029 0.040 NK 38.10 44.45 1.500 1.750 HL 6.35 --- 0.250 --- 2M 45 BSC 45 BSC 13 _ _ N 5.08 BSC 0.200 BSC P --- 1.27 --- 0.050 MJR 1.37 BSC 0.054 BSC T --- 0.76 --- 0.030 LEAD IDENTIFICATIONU 2.54 --- 0.100 --- CDETAIL STYLE 1: PIN 1. EMITTER 2. BASE 3. COLLECTOR TO−39 3−Lead CASE 205AB ISSUE A B NOTES: 1. DIMENSIONING AND TOLERANCING PER ASME Y14.5M, 1994. ADETAIL X 2. CONTROLLING DIMENSION: INCHES. B 3. DIMENSION J MEASURED FROM DIAMETER A TO EDGE. 4. LEAD TRUE POSITION TO BE DETERMINED AT THE GUAGE UPC PLANE DEFINED BY DIMENSION R. 5. DIMENSION F APPLIES BETWEEN DIMENSION P AND L. U 6. DIMENSION D APPLIES BETWEEN DIMENSION L AND K. 7. BODY CONTOUR OPTIONAL WITHIN ZONE DEFINED BY DIMEN LSEATING SIONS A, B, AND T. RA PLANEF 8. DIMENSION B SHALL NOT VARY MORE THAN 0.010 IN ZONE P. KNOTE 5MILLIMETERSINCHESDIMMINMAXMINMAXEA 8.89 9.40 0.350 0.370 TB 8.00 8.51 0.315 0.335 NOTE 7C 6.10 6.60 0.240 0.260 DETAIL X3XDD 0.41 0.48 0.016 0.019 NOTES 4 & 6E 0.23 3.18 0.009 0.125 0.007 (0.18MM) A B S C M F 0.41 0.48 0.016 0.019 H 0.71 0.86 0.028 0.034 J 0.73 1.02 0.029 0.040 NK 12.70 14.73 0.500 0.580 HL 6.35 --- 0.250 --- 2M 45 BSC 45 BSC 13 _ _ N 5.08 BSC 0.200 BSC P --- 1.27 --- 0.050 MJR 1.37 BSC 0.054 BSC T --- 0.76 --- 0.030 LEAD IDENTIFICATIONU 2.54 --- 0.100 --- CDETAIL STYLE 1: PIN 1. EMITTER 2. BASE 3. COLLECTOR http://onsemi.com3
