Datasheet AD8042 (Analog Devices) - 8
DescriptionDual 160 MHz Rail-to-Rail Amplifier
Pages / Page16 / 8 — AD8042. 0.04 NTSC SUBCARRIER (3.579MHz). VS = +5V. ) 0.03. G = +2. 300. L …
RevisionE
File Format / SizePDF / 335 Kb
AD8042. 0.04 NTSC SUBCARRIER (3.579MHz). VS = +5V. ) 0.03. G = +2. 300. L %. RL = 150Ω TO 2.5V. IA (. T RO 0.02. 100. S = ±5V. E 0.01. FFEREN IN
AD8042 0.04 NTSC SUBCARRIER (3.579MHz) VS = +5V ) 0.03 G = +2 300 L % RL = 150Ω TO 2.5V IA ( T RO 0.02 100 S = ±5V E 0.01 FFEREN IN
AD8042 0.04 NTSC SUBCARRIER (3.579MHz) VS = +5V ) 0.03 G = +2 300 L % RL = 150Ω TO 2.5V z) IA ( T RO 0.02 H R V V/ 100 R S = ±5V E 0.01 G = +2 (n FFEREN IN E DI A RL = 150Ω IS G 0 O 30 N E –0.01 G 0.05 A 10 V T S = +5V L 0.04 G = +2 rees) L R VO eg L = 150Ω TO 2.5V T 3 IA D 0.03 NT ( PU R O 0.02 RE IN E RR 1 F IF E 0.01 V
1
S = ±5V D E
4 01
S G = +2
9-
A 0
-01 05
R PH
59
L = 150Ω
01
–0.01
010
10 100 1k 10k 100k 1M 10M 100M 1G 0 10 20 30 40 50 60 70 80 90 100 FREQUENCY (Hz) MODULATING RAMP LEVEL (IRE)
Figure 11. Input Voltage Noise vs. Frequency Figure 14. Differential Gain and Phase Errors
–30 0.6 VS = 5V V 0.5 G = +2 –40 S = 3V, AV = –1, Bc) R RF = 200Ω d L = 100Ω TO 1.5V 0.4 RL = 150Ω TO 2.5V N ( IO –50 VS = 5V, AV = +2, R B) d 0.3 RT L = 100Ω TO 2.5V O N ( T V S –60 S = 5V, AV = +1, AI 0.2 R DI L = 100Ω TO 2.5V C D G E 0.1 NI –70 IZ O AL 0 14MHz RM –80 HARM –0.1 NO AL V T S = 5V, AV = +2, –0.2 O –90 RL = 1kΩ TO 2.5V T
2
VS = 5V, AV = +1,
5 -01
R –0.3 L = 1kΩ TO 2.5V
-01 59 59
–100
010
–0.4
010
1 2 3 4 5 6 7 8 9 10 1 10 100 500 FUNDAMENTAL FREQUENCY (MHz) FREQUENCY (MHz)
Figure 12. Total Harmonic Distortion vs. Frequency Figure 15. 0.1 dB Gain Flatness
–30 120 VS = 5V, G = +2, VS = 5V RL = 1kΩ TO 2.5V G = +2 –40 100 RF = 200Ω 80 RL = 150Ω TO 2.5V –50 c) ) GAIN B 10MHz d B 60 45 d ( C ( –60 IN NI 40 0 rees) O 5MHz GA eg –70 RM D 20 –45 ( E OOP PHASE HA T –80 -L 0 –90 N HAS RS E P O 1MHz –20 –135 W OP –90 –40 –180 –100
3 6 -01
–60 –225
-01 59 59
–110
010
–80 –270
010
0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 0.01 0.1 1 10 100 500 OUTPUT VOLTAGE (V p-p) FREQUENCY (MHz)
Figure 13. Worst Harmonic vs. Output Voltage Figure 16. Open-Loop Gain and Phase vs. Frequency Rev. E | Page 8 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION CONNECTION DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS MAXIMUM POWER DISSIPATION ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION CIRCUIT DESCRIPTION DRIVING CAPACITIVE LOADS OVERDRIVE RECOVERY Single-Supply Composite Video Line Driver Single-Ended-to-Differential Driver Single-Supply Differential A/D Driver HDSL Line Driver LAYOUT CONSIDERATIONS OUTLINE DIMENSIONS ORDERING GUIDE
