Datasheet LT6105 (Analog Devices) - 20
DescriptionPrecision, Extended Input Range Current Sense Amplifier
Pages / Page20 / 20 — TYPICAL APPLICATION. Supply Monitoring
File Format / SizePDF / 384 Kb
TYPICAL APPLICATION Supply Monitoring
LT6105
TYPICAL APPLICATION
V
Supply Monitoring
OUT = 1V/A V LT6105 OUT 4.99k The input common mode range of the LT6105 also makes V – –15V 1% it suitable for monitoring either positive or negative sup- plies. Figure 7 shows one LT6105 applied as a simple V+ 5VDC positive supply monitor, and another LT6105 as a simple negative supply monitor. Note that the schematics are practically identical and both have outputs conveniently +IN –IN referred to ground. The only requirement for negative 100Ω 100Ω 20mΩ supply monitoring, in addition to the usual constraints of 1% 1% 1% +15V + – TO +15V the absolute maximum ratings, is that the negative supply POSITIVE LOAD SUPPLY to that LT6105 be at least as negative as the supply it is CURRENT FLOW monitoring. CURRENT FLOW –15V TO –15V – + NEGATIVE LOAD 20mΩ SUPPLY 100Ω 100Ω 1% 1% 1% LT6105 –IN +IN 5V V+ DC –15V V– VOUT = 1V/A VOUT 6105 F07 4.99k 1%
Figure 7. The LT6105 Can Monitor the Current of Either Positive or Negative Supplies, Without a Schematic Change. Just Ensure That the Current Flow Is in the Correct Direction RELATED PARTS PART NUMBER DESCRIPTION COMMENTS
LT1787/LT1787HV Precision, Bidirectional, High Side Current Sense Amplifi er 2.7V to 60V Operation, 75μV Offset, 60μA Current Draw LTC4150 Coulomb Counter/Battery Gas Gauge Indicates Charge Quantity and Polarity LT6100 Gain-Selectable High Side Current Sense Amplifi er 4.1V to 48V Operation, Pin-Selectable Gain: 10V/V, 12.5V/V, 20V/V, 25V/V, 40V/V, 50V/V LTC6101/ High Voltage High Side Current Sense Amplifi er 4V to 60V/5V to 100V Operation, External Resistor Set Gain, SOT23 LTC6101HV LTC6102/ Zero Drift High Side Current Sense Amplifi er 4V to 60V/5V to 100V Operation, ±10μV Offset, 1μs Step Response, LTC6102HV MSOP8 / DFN LTC6103 Dual High Side Precision Current Sense Amplifi er 4V to 60V, Gain Confi gurable, 8-Pin MSOP LTC6104 Bidirectional High Side Precision Current Sense Amplifi er 4V to 60V, Gain Confi gurable, 8-Pin MSOP LT6106 Low Cost, High Side Precision Current Sense Amplifi er 2.7V to 36V, Gain Confi gurable, SOT23 6105fa 20 Linear Technology Corporation LT 0408 REV A • PRINTED IN USA 1630 McCarthy Blvd., Milpitas, CA 95035-7417 (408) 432-1900 ● FAX: (408) 434-0507 ● www.linear.com © LINEAR TECHNOLOGY CORPORATION 2007
