Datasheet LT1567 (Analog Devices) - 3
Description1.4nV/√Hz 180MHz Filter Building Block
Pages / Page16 / 3 — ELECTRICAL CHARACTERISTICS. The
File Format / SizePDF / 208 Kb
LT1567
denotes the specifications that apply over the full operating temperature range (Note 4), otherwise specifications and typical values are at TA = 25
C. VS =
2.5V, RL = 1K, VOUT = 0 on both amplifiers unless otherwise noted. PARAMETER CONDITIONS MIN TYP MAX UNITS
OA Input Bias Current ● 3 10 µA DC BIAS Input Bias Current ● 6 15 µA OA DC Open-Loop Gain VS = ±1.5V, RL = 1k, VO = –1V to 1V ● 7.5 55 V/mV VS = ±2.5V, RL = 1k, VO= –2V to 2V ● 10 60 V/mV VS = ±2.5V, RL = 100, VO = –1.5V to 1.5V ● 1.2 7.0 V/mV VS = ±5V, RL = 1k, VO = –4V to 4V ● 10 80 V/mV INV DC Gain VS = ±1.5V, RL = 1k, VIN = –1V to 1V ● 0.97 1.04 V/V VS = ±2.5V, RL = 1k, VIN = –2V to 2V ● 0.97 1.04 V/V VS = ±2.5V, RL = 100, VIN = –1.5V to 1.5V ● 0.97 1.04 V/V VS = ±5V, RL = 1k, VIN = –4V to 4V ● 0.97 1.04 V/V INV DC Input Resistance VS = ±2.5V, RL = 1k, VIN = –2V to 2V ● 450 600 750 Ω OA Gain Bandwidth Product Measured at 2MHz, VS = ±1.5V ● 100 180 MHz Measured at 2MHz, VS = ±2.5V ● 110 185 MHz Measured at 2MHz, VS = ±5V ● 120 190 MHz INV Bandwidth –3dB 85 MHz INV AC Gain Measured at 2MHz ● 0.96 1.0 1.05 V/V OA Slew Rate VS = ±5V 55 V/µs INV Slew Rate VS = ±5V 90 V/µs OA Input Voltage Noise Density (Note 7) f = 100kHz 1.4 nV/√Hz OA Input Current Noise Density f = 100kHz 1.0 pA/√Hz Wideband Output Noise for a Second Order Filter (Figure 1) fC = 2MHz, BW = 4MHz (Note 8) 20 µVRMS fC = 5MHz, BW = 10MHz (Note 8) 30 µVRMS Total Harmonic Distortion (THD) f = 1MHz, fC = 2MHz, VOUT = 1VRMS –88 dB for a Second Order Filter (Figure 1) f = 2.5MHz, fC = 5MHz, VOUT = 1VRMS –70 dB Output Short-Circuit Current (Note 9) ● 8 50 mA OA Output Impedance f = 100kHz, OA Connected as 0.03 Ω Unity-Gain Inverter INV Output Impedance f = 100kHz 0.7 Ω
Note 1:
Note 5:
With INVIN pin driven to ±2V. may cause permanent damage to the device. Exposure to any Absolute
Note 6:
This parameter is not 100% tested. Maximum Rating condition for extended periods may affect device
Note 7:
The input referred voltage noise density of the unity gain inverter reliability and lifetime. is 5.6nV/√Hz which includes the noise of the gain setting resistors.
Note 2:
The inputs of each op amp are protected by back-to-back diodes
Note 8:
For fC = 2MHz, C1 = C2 = 180pF, R1 = R2 = 604Ω, R3 = 316Ω and and diodes to each supply. If either input exceeds the supply or the for fC = 5MHz, C1 = C2 = 180pF, R1 = R2 = 232Ω, R1 = 130Ω. BW is the differential input voltage exceeds 1.4V, the input current should be limited bandwidth of the noise measurement (Figure 1 circuit). to less than 25mA.
Note 9:
Under direct short circuit conditions, with TA < 25°C the output
Note 3:
The LT1567C and LT1567I are guaranteed functional over the current is reduced. operating temperature range –40°C to 85°C.
Note 4:
The LT1567C is guaranteed to meet specified performance from 0°C to 70°C. The LT1567C is designed, characterized and expected to meet specified performance from –40°C to 85°C but not tested or QA sampled at these temperatures. The LT1567I is guaranteed to meet specified performance from – 40°C to 85°C. 1567fa 3
