Datasheet MCP6286 (Microchip) - 17
ManufacturerMicrochip
DescriptionThe MCP6286 operational amplifier offers low noise, low power and rail-to-rail output operation
Pages / Page28 / 17 — MCP6286. 4.6. Application Circuits. FIGURE 4-6:. FIGURE 4-8:. FIGURE …
File Format / SizePDF / 416 Kb
MCP6286. 4.6. Application Circuits. FIGURE 4-6:. FIGURE 4-8:. FIGURE 4-7:. FIGURE 4-9:
MCP6286 4.6 Application Circuits FIGURE 4-6: FIGURE 4-8: FIGURE 4-7: FIGURE 4-9:
link to page 17 link to page 17 link to page 17 link to page 17 link to page 17 link to page 17 link to page 17 link to page 17
4.6.2 PHOTO DETECTION The MCP6286 op amps can be used to easily convert 4.6.1 ACTIVE LOW-PASS FILTER the signal from a sensor that produces an output The MCP6286 op amp’s low input bias current makes current (such as a photo diode) into a voltage (a it possible for the designer to use larger resistors and transimpedance amplifier). This is implemented with a smaller capacitors for active low-pass filter single resistor (R2) in the feedback loop of the applications. However, as the resistance increases, the amplifiers shown in Figure 4-8 and Figure 4-9. The noise generated also increases. Parasitic capacitances optional capacitor (C2) sometimes provides stability for and the large value resistors could also modify the these circuits. frequency response. These trade-offs need to be A photodiode configured in the Photovoltaic mode has considered when selecting circuit elements. zero voltage potential placed across it (Figure 4-8). In Figure 4-6 and Figure 4-7 show low-pass, this mode, the light sensitivity and linearity is second-order, Butterworth filters with a cut-off maximized, making it best suited for precision frequency of 10 Hz. The filter in Figure 4-6 has a applications. The key amplifier specifications for this non-inverting gain of +1 V/V, and the filter in Figure 4-7 application are: low input bias current, low noise, has an inverting gain of -1 V/V. common mode input voltage range (including ground), and rail-to-rail output. C G = +1 V/V 1 C2 47 nF fP = 10 Hz R2 R R 1 2 VOUT I 382 kΩ 641 kΩ D1 VDD V – IN + D1 C2
MCP6286
VOUT Light
MCP6286
22 nF – + VOUT = ID1*R2
FIGURE 4-6:
Second-Order, Low-Pass Butterworth Filter with Sallen-Key Topology.
FIGURE 4-8:
Photovoltaic Mode Detector. In contrast, a photodiode that is configured in the Photoconductive mode has a reverse bias voltage G = -1 V/V across the photo-sensing element (Figure 4-9). This R2 fP = 10 Hz decreases the diode capacitance, which facilitates 618 kΩ high-speed operation (e.g., high-speed digital communications). The design trade-off is increased R R 1 3 C1 diode leakage current and linearity errors. The op amp 618 kΩ 1.00 MΩ 8.2 nF needs to have a wide Gain Bandwidth Product V V IN OUT (GBWP). C 2 – 47 nF
MCP6286
C2 VDD/2 + R2 ID1 V
FIGURE 4-7:
Second-Order, Low-Pass OUT VDD Butterwork Filter with Multiple-Feedback – D Topology. 1 Light
MCP6286
V + V BIAS OUT = ID1*R2 VBIAS < 0V
FIGURE 4-9:
Photoconductive Mode Detector. © 2009 Microchip Technology Inc. DS22196A-page 17 Document Outline 1.0 Electrical Characteristics 1.1 Absolute Maximum Ratings † 1.2 Test Circuits FIGURE 1-1: AC and DC Test Circuit for Most Specifications. 2.0 Typical Performance Curves FIGURE 2-1: Input Offset Voltage. FIGURE 2-2: Input Offset Voltage Drift. FIGURE 2-3: Input Offset Voltage vs. Common Mode Input Voltage with VDD = 5.5V. FIGURE 2-4: Input Offset Voltage vs. Common Mode Input Voltage with VDD = 2.2V. FIGURE 2-5: Input Offset Voltage vs. Output Voltage. FIGURE 2-6: Input Offset Voltage vs. Power Supply Voltage with VCM = VCMR_L. FIGURE 2-7: Input Offset Voltage vs. Power Supply Voltage with VCM = VCMR_H. FIGURE 2-8: Input Noise Voltage Density vs. Frequency. FIGURE 2-9: Input Noise Voltage Density vs. Common Mode Input Voltage. FIGURE 2-10: CMRR, PSRR vs. Frequency. FIGURE 2-11: CMRR, PSRR vs. Ambient Temperature. FIGURE 2-12: Common Mode Input Voltage Headroom vs. Ambient Temperature. FIGURE 2-13: Input Bias, Offset Currents vs. Ambient Temperature. FIGURE 2-14: Input Bias Current vs. Common Mode Input Voltage. FIGURE 2-15: Quiescent Current vs Ambient Temperature. FIGURE 2-16: Quiescent Current vs. Power Supply Voltage. FIGURE 2-17: Open-Loop Gain, Phase vs. Frequency. FIGURE 2-18: Gain Bandwidth Product, Phase Margin vs. Common Mode Input Voltage with VDD = 5.5V. FIGURE 2-19: Gain Bandwidth Product, Phase Margin vs. Common Mode Input Voltage with VDD = 2.2V. FIGURE 2-20: Gain Bandwidth Product, Phase Margin vs. Ambient Temperature with VDD = 5.5V. FIGURE 2-21: Gain Bandwidth Product, Phase Margin vs. Ambient Temperature with VDD = 2.2V. FIGURE 2-22: Ouput Short Circuit Current vs. Power Supply Voltage. FIGURE 2-23: Output Voltage Swing vs. Frequency. FIGURE 2-24: Output Voltage Headroom vs. Output Current. FIGURE 2-25: Output Voltage Headroom vs. Ambient Temperature. FIGURE 2-26: Slew Rate vs. Ambient Temperature. FIGURE 2-27: Small Signal Non-Inverting Pulse Response. FIGURE 2-28: Small Signal Inverting Pulse Response. FIGURE 2-29: Large Signal Non-Inverting Pulse Response. FIGURE 2-30: Large Signal Inverting Pulse Response. FIGURE 2-31: The MCP6286 Shows No Phase Reversal. FIGURE 2-32: Closed Loop Output Impedance vs. Frequency. FIGURE 2-33: Measured Input Current vs. Input Voltage (below VSS). 3.0 Pin Descriptions TABLE 3-1: Pin Function Table 3.1 Analog Output 3.2 Analog Inputs 3.3 Power Supply Pins 4.0 Application Information 4.1 Input FIGURE 4-1: Simplified Analog Input ESD Structures. FIGURE 4-2: Protecting the Analog Inputs. 4.2 Rail-to-Rail Output 4.3 Capacitive Loads FIGURE 4-3: Output Resistor, RISO Stabilizes Large Capacitive Loads. FIGURE 4-4: Recommended RISO Values for Capacitive Loads. 4.4 Supply Bypass 4.5 PCB Surface Leakage FIGURE 4-5: Example Guard Ring Layout for Inverting Gain. 4.6 Application Circuits FIGURE 4-6: Second-Order, Low-Pass Butterworth Filter with Sallen-Key Topology. FIGURE 4-7: Second-Order, Low-Pass Butterwork Filter with Multiple-Feedback Topology. FIGURE 4-8: Photovoltaic Mode Detector. FIGURE 4-9: Photoconductive Mode Detector. 5.0 Design Aids 5.1 SPICE Macro Model 5.2 FilterLab® Software 5.3 Mindi™ Circuit Designer & Simulator 5.4 Microchip Advanced Part Selector (MAPS) 5.5 Analog Demonstration and Evaluation Boards 5.6 Application Notes 6.0 Packaging Information 6.1 Package Marking Information
