Datasheet ADA4622-1, ADA4622-2, ADA4622-4 (Analog Devices) - 11
Description30 V, 8 MHz, Low Bias Current, Single-Supply, RRO, Precision Quad Op Amp
Pages / Page37 / 11 — Data Sheet. ADA4622-1/. ADA4622-2/. ADA4622-4. OUT A 1. –IN A 2. …
RevisionE
Data Sheet. ADA4622-1/. ADA4622-2/. ADA4622-4. OUT A 1. –IN A 2. ADA4622-2. OUT B. TOP VIEW. +IN A 3. –IN B. (Not to Scale). +IN B. OUT A. –IN A
Data Sheet ADA4622-1/ ADA4622-2/ ADA4622-4 OUT A 1 –IN A 2 ADA4622-2 OUT B TOP VIEW +IN A 3 –IN B (Not to Scale) +IN B OUT A –IN A
Data Sheet ADA4622-1/ ADA4622-2/ ADA4622-4 OUT A 1 8 V+ –IN A 2 ADA4622-2 7 OUT B TOP VIEW +IN A 3 6 –IN B (Not to Scale)
101
V– 4 5 +IN B
13502- Figure 4. 8-Lead MSOP Pin Configuration, ADA4622-2
ADA4622-2 OUT A 1 8 V+ –IN A 2 7 OUT B TOP VIEW +IN A 3 6 (Not to Scale) –IN B V– 4 5 +IN B
201 13502- Figure 5. 8-Lead SOIC Pin Configuration, ADA4622-2
Table 8. 8-Lead MSOP and 8-Lead SOIC Pin Function Descriptions, ADA4622-2 Pin No. Mnemonic Description
1 OUT A Output, Channel A. 2 −IN A Inverting Input, Channel A. 3 +IN A Noninverting Input, Channel A. 4 V− Negative Supply Voltage. 5 +IN B Noninverting Input, Channel B. 6 −IN B Inverting Input, Channel B. 7 OUT B Output, Channel B. 8 V+ Positive Supply Voltage.
OUT A 1 8 V+ –IN A 2 7 OUT B ADA4622-2 +IN A 3 TOP VIEW 6 –IN B (Not to Scale) V– 4 5 +IN B NOTES
102
1. IT IS RECOMMENDED TO CONNECT THE EXPOSED PAD TO THE V+ PIN.
13502- Figure 6. 8-Lead LFCSP Pin Configuration, ADA4622-2
Table 9. 8-Lead LFCSP Pin Function Descriptions, ADA4622-2 Pin No. Mnemonic Description
1 OUT A Output, Channel A. 2 −IN A Inverting Input, Channel A. 3 +IN A Noninverting Input, Channel A. 4 V− Negative Supply Voltage. 5 +IN B Noninverting Input, Channel B. 6 −IN B Inverting Input, Channel B. 7 OUT B Output, Channel B. 8 V+ Positive Supply Voltage. EPAD Exposed Pad. It is recommended to connect the exposed pad to the V+ pin. Rev. C | Page 11 of 37 Document Outline FEATURES APPLICATIONS PIN CONFIGURATION GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS, VSY = ±15 V ELECTRICAL CHARACTERISTICS, VSY = ±5 V ELECTRICAL CHARACTERISTICS, VSY = 5 V ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION INPUT CHARACTERISTICS Input Overvoltage Protection EMI Rejection Ratio OUTPUT CHARACTERISTICS Capacitive Load Drive Capability SHUTDOWN OPERATION APPLICATIONS INFORMATION RECOMMENDED POWER SOLUTION MAXIMUM POWER DISSIPATION SECOND-ORDER LOW-PASS FILTER WIDEBAND PHOTODIODE PREAMPLIFIER PEAK DETECTOR MULTIPLEXING INPUTS FULL WAVE RECTIFIER OUTLINE DIMENSIONS ORDERING GUIDE
