Datasheet AD8657, AD8659 (Analog Devices) - 8
Description22 μA, RRIO, CMOS, 18 V Quad Operational Amplifier
Pages / Page24 / 8 — AD8657/AD8659. Data Sheet. OUT A 1. 14 OUT D. T A. T D. –IN A. 13 –IN D. …
RevisionC
File Format / SizePDF / 867 Kb
AD8657/AD8659. Data Sheet. OUT A 1. 14 OUT D. T A. T D. –IN A. 13 –IN D. +IN A. 12 +IN D. AD8659. TOP VIEW. 11 V–. (Not to Scale). –IN A 1. 12 –IN D
AD8657/AD8659 Data Sheet OUT A 1 14 OUT D T A T D –IN A 13 –IN D +IN A 12 +IN D AD8659 TOP VIEW 11 V– (Not to Scale) –IN A 1 12 –IN D
link to page 8 link to page 10 link to page 10
AD8657/AD8659 Data Sheet OUT A 1 14 OUT D T A T D C –IN A NI OU OU NC 2 13 –IN D +IN A 16 15 14 13 3 12 +IN D AD8659 V+ 4 TOP VIEW 11 V– (Not to Scale) –IN A 1 12 –IN D +IN B 5 10 +IN C +IN A 2 11 +IN D –IN B AD8659 6 9 –IN C
103
V+ 3 TOP VIEW 10 V– OUT B 7 8 OUT C (Not to Scale)
08804-
+IN B 4 9 +IN C 5 6 7 8 N B T B T C N C –I –I OU OU NOTES 1. NIC = NO INTERNAL CONNECTION.
104
2. CONNECT THE EXPOSED PAD TO V– OR LEAVE IT UNCONNECTED.
08804- Figure 6. AD8659 Pin Configuration, 14-Lead SOIC_N Figure 7. AD8659 Pin Configuration, 16-Lead LFCSP
Table 8. Pin Function Descriptions, AD8659 Pin No.1 14-Lead SOIC 16-Lead LFCSP Mnemonic Description
1 15 OUT A Output Channel A. 2 1 −IN A Negative Input Channel A. 3 2 +IN A Positive Input Channel A. 11 10 V− Negative Supply Voltage. 5 4 +IN B Positive Input Channel B. 6 5 −IN B Negative Input Channel B. 7 6 OUT B Output Channel B. 4 3 V+ Positive Supply Voltage. 8 7 OUT C Output Channel C. 9 8 −IN C Negative Input Channel C. 10 9 +IN C Positive Input Channel C. 12 11 +IN D Positive Input Channel D. 13 12 −IN D Negative Input Channel D. 14 14 OUT D Output Channel D. N/A 13 NIC No Internal Connection. N/A 16 NIC No Internal Connection. N/A EP2 EPAD2 Exposed Pad. For the AD8659 (16-lead LFCSP only), connect the exposed pad to V− or leave it unconnected. 1 N/A means not applicable. 2 The exposed pad is not shown in the pin configuration diagram. Rev. C | Page 8 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONNECTION DIAGRAMS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—18 V OPERATION ELECTRICAL CHARACTERISTICS—10 V OPERATION ELECTRICAL CHARACTERISTICS—2.7 V OPERATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION INPUT STAGE OUTPUT STAGE RAIL TO RAIL RESISTIVE LOAD Inverting Op Amp Configuration Noninverting Op Amp Configuration COMPARATOR OPERATION—AD8657 EMI REJECTION RATIO 4 mA TO 20 mA PROCESS CONTROL CURRENT LOOP TRANSMITTER—AD8657 OUTLINE DIMENSIONS ORDERING GUIDE
