Datasheet AD827 (Analog Devices) - 10
DescriptionHigh Speed, Low Power Dual Op Amp
Pages / Page13 / 10 — AD827. OUTLINE DIMENSIONS. 8-Lead Plastic Dual-in-Line Package [PDIP]
RevisionC
File Format / SizePDF / 248 Kb
AD827 OUTLINE DIMENSIONS 8-Lead Plastic Dual-in-Line Package [PDIP]
AD827
AD827 OUTLINE DIMENSIONS 8-Lead Plastic Dual-in-Line Package [PDIP] 8-Lead Ceramic DIP-Glass Hermetic Seal Package [CERDIP] (N-8) (Q-8)
Dimensions shown in millimeters and (inches) Dimensions shown in millimeters and (inches)
10.92 (0.4299) 0.13 (0.0051) 1.40 (0.0551) 8.84 (0.3480) MIN MAX 8 5 8 5 7.11 (0.2799) 7.87 (0.3089) 6.10 (0.2402) 1 4 PIN 1 5.59 (0.2201) 1 4 PIN 1 8.25 (0.3248) 2.54 (0.1000) 7.62 (0.3000) 2.54 (0.1000) BSC BSC 8.13 (0.3201) 10.29 (0.4051) MAX 7.37 (0.2902) 5.33 1.52 (0.0598) 4.95 (0.1949) 1.52 (0.0600) (0.2098) 0.38 (0.0150) 2.93 (0.1154) 5.08 (0.2000) 0.38 (0.0150) MAX ( 3.30 MAX 4.06 (0.1598) (0.1299) 0.38 (0.0150) 2.93 (0.1154) 5.08 (0.2000) 3.81 (0.1500) MIN 0.20 (0.0079) MIN 3.18 (0.1252) 0.56 (0.0220) SEATING 1.77 (0.0697) 0.36 (0.0142) PLANE 0.38 (0.0150) 0.58 (0.0228) SEATING 1.15 (0.0453) 1.78 (0.0701) 15 PLANE 0.20 (0.0079) 0.36 (0.0142) 0 0.76 (0.0299) CONTROLLING DIMENSIONS ARE IN MILLIMETERS; INCH DIMENSIONS (IN PARENTHESES) ARE ROUNDED-OFF MILLIMETER EQUIVALENTS FOR CONTROLLING DIMENSIONS ARE IN MILLIMETERS; INCH DIMENSIONS REFERENCE ONLY AND ARE NOT APPROPRIATE FOR USE IN DESIGN (IN PARENTHESES) ARE ROUNDED-OFF MILLIMETER EQUIVALENTS FOR REFERENCE ONLY AND ARE NOT APPROPRIATE FOR USE IN DESIGN 16-Lead Standard Small Outline Package [SOIC] 20-Terminal Ceramic Leadless Chip Carrier [LCC] Wide Body (E-20A) (R-16)
1.91 5.08 (0.2000) (0.0752) BSC 10.50 (0.4134) 2.54 (0.1000) REF 10.10 (0.3976) 1.63 (0.0642) 2.54 (0.1000) BSC 2.41 (0.0949) 1.90 (0.0748) 0.38 (0.0150) 19 3 MIN 16 9 20 18 4 0.71 (0.0278) 7.60 (0.2992) 9.09 1 9.09 (0.3579) 0.28 (0.0110) (0.3579) BOTTOM 0.56 (0.0220) 7.40 (0.2913) 8.69 (0.3421) MAX 0.18 (0.0071) VIEW SQ 1.27 (0.0500) 10.65 (0.4193) SQ R TYP 14 8 BSC 1 8 1.91 (0.0752) 10.00 (0.3937) 13 9 REF 45 TYP 2.24 (0.0882) 1.40 (0.0551) 3.81 (0.1500) 1.37 (0.0539) 1.14 (0.0449) PIN 1 2.65 (0.1043) BSC 1.27 (0.0500) 0.75 (0.0295) BSC 2.35 (0.0925)
ⴛ
45
ⴗ
0.25 (0.0098) CONTROLLING DIMENSIONS ARE IN MILLIMETERS; INCH DIMENSIONS 0.30 (0.0118) (IN PARENTHESES) ARE ROUNDED-OFF MILLIMETER EQUIVALENTS FOR 0.10 (0.0039) REFERENCE ONLY AND ARE NOT APPROPRIATE FOR USE IN DESIGN 8
ⴗ
0.51 (0.0201) SEATING 0
ⴗ
0.32 (0.0126) 1.27 (0.0500) COPLANARITY 0.33 (0.0130) PLANE 0.10 0.23 (0.0091) 0.40 (0.0157) CONTROLLING DIMENSIONS ARE IN MILLIMETERS; INCH DIMENSIONS (IN PARENTHESES) ARE ROUNDED-OFF MILLIMETER EQUIVALENTS FOR REFERENCE ONLY AND ARE NOT APPROPRIATE FOR USE IN DESIGN COMPLIANT TO JEDEC STANDARDS MS-013AA
REV. C –9– Document Outline FEATURES CONNECTION DIAGRAMS PRODUCT DESCRIPTION APPLICATION HIGHLIGHTS SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ORDERING GUIDE METALLIZATION PHOTOGRAPH Typical Performance Characteristics INPUT PROTECTION PRECAUTIONS VIDEO LINE DRIVER A HIGH SPEED THREE OP AMP INSTRUMENTATION AMPLIFIER CIRCUIT A TWO-CHIP VOLTAGE-CONTROLLED AMPLIFIER (VCA) WITH EXPONENTIAL RESPONSE Guidelines for Grounding and Bypassing OUTLINE DIMENSIONS Revision History
