Datasheet LTC2229 (Analog Devices) - 24
Description | 12-Bit, 80Msps Low Power 3V ADC |
Pages / Page | 24 / 24 — RELATED PARTS. PART NUMBER. DESCRIPTION. COMMENTS |
File Format / Size | PDF / 566 Kb |
LTC2229
RELATED PARTS PART NUMBER DESCRIPTION COMMENTS
LTC1748 14-Bit, 80Msps, 5V ADC 76.3dB SNR, 90dB SFDR, 48-Pin TSSOP Package LTC1750 14-Bit, 80Msps, 5V Wideband ADC Up to 500MHz IF Undersampling, 90dB SFDR LT1993-2 High Speed Differential Op Amp 800MHz BW, 70dBc Distortion at 70MHz, 6dB Gain LT1994 Low Noise, Low Distortion Fully Differential Low Distortion: –94dBc at 1MHz Input/Output Amplifier/Driver LTC2202 16-Bit, 10Msps, 3.3V ADC, Lowest Noise 150mW, 81.6dB SNR, 100dB SFDR, 48-Pin QFN LTC2208 16-Bit, 130Msps, 3.3V ADC, LVDS Outputs 1250mW, 78dB SNR, 100dB SFDR, 64-Pin QFN LTC2220-1 12-Bit, 185Msps, 3.3V ADC, LVDS Outputs 910mW, 67.7dB SNR, 80dB SFDR, 64-Pin QFN LTC2224 12-Bit, 135Msps, 3.3V ADC, High IF Sampling 630mW, 67.6dB SNR, 84dB SFDR, 48-Pin QFN LTC2225 12-Bit, 10Msps, 3V ADC, Lowest Power 60mW, 71.3dB SNR, 90dB SFDR, 32-Pin QFN LTC2226 12-Bit, 25Msps, 3V ADC, Lowest Power 75mW, 71.4dB SNR, 90dB SFDR, 32-Pin QFN LTC2227 12-Bit, 40Msps, 3V ADC, Lowest Power 120mW, 71.4dB SNR, 90dB SFDR, 32-Pin QFN LTC2228 12-Bit, 65Msps, 3V ADC, Lowest Power 205mW, 71.3dB SNR, 90dB SFDR, 32-Pin QFN LTC2229 12-Bit, 80Msps, 3V ADC, Lowest Power 211mW, 70.6dB SNR, 90dB SFDR, 32-Pin QFN LTC2236 10-Bit, 25Msps, 3V ADC, Lowest Power 75mW, 61.8dB SNR, 85dB SFDR, 32-Pin QFN LTC2237 10-Bit, 40Msps, 3V ADC, Lowest Power 120mW, 61.8dB SNR, 85dB SFDR, 32-Pin QFN LTC2238 10-Bit, 65Msps, 3V ADC, Lowest Power 205mW, 61.8dB SNR, 85dB SFDR, 32-Pin QFN LTC2239 10-Bit, 80Msps, 3V ADC, Lowest Power 211mW, 61.6dB SNR, 85dB SFDR, 32-Pin QFN LTC2245 14-Bit, 10Msps, 3V ADC, Lowest Power 60mW, 74.4dB SNR, 90dB SFDR, 32-Pin QFN LTC2246 14-Bit, 25Msps, 3V ADC, Lowest Power 75mW, 74.5dB SNR, 90dB SFDR, 32-Pin QFN LTC2247 14-Bit, 40Msps, 3V ADC, Lowest Power 120mW, 74.4dB SNR, 90dB SFDR, 32-Pin QFN LTC2248 14-Bit, 65Msps, 3V ADC, Lowest Power 205mW, 74.3dB SNR, 90dB SFDR, 32-Pin QFN LTC2249 14-Bit, 80Msps, 3V ADC, Lowest Power 222mW, 73dB SNR, 90dB SFDR, 32-Pin QFN LTC2250 10-Bit, 105Msps, 3V ADC, Lowest Power 320mW, 61.6dB SNR, 85dB SFDR, 32-Pin QFN LTC2251 10-Bit, 125Msps, 3V ADC, Lowest Power 395mW, 61.6dB SNR, 85dB SFDR, 32-Pin QFN LTC2252 12-Bit, 105Msps, 3V ADC, Lowest Power 320mW, 70.2dB SNR, 88dB SFDR, 32-Pin QFN LTC2253 12-Bit, 125Msps, 3V ADC, Lowest Power 395mW, 70.2dB SNR, 88dB SFDR, 32-Pin QFN LTC2254 14-Bit, 105Msps, 3V ADC, Lowest Power 320mW, 72.4dB SNR, 88dB SFDR, 32-Pin QFN LTC2255 14-Bit, 125Msps, 3V ADC, Lowest Power 395mW, 72.5dB SNR, 88dB SFDR, 32-Pin QFN LTC2284 14-Bit, Dual, 105Msps, 3V ADC, Low Crosstalk 540mW, 72.4dB SNR, 88dB SFDR, 64-Pin QFN LT5512 DC-3GHz High Signal Level Downconverting Mixer DC to 3GHz, 21dBm IIP3, Integrated LO Buffer LT5514 Ultralow Distortion IF Amplifier/ADC Driver 450MHz to 1dB BW, 47dB OIP3, Digital Gain Control with Digitally Controlled Gain 10.5dB to 33dB in 1.5dB/Step LT5515 1.5GHz to 2.5GHz Direct Conversion Quadrature Demodulator High IIP3: 20dBm at 1.9GHz, Integrated LO Quadrature Generator LT5516 800MHz to 1.5GHz Direct Conversion Quadrature Demodulator High IIP3: 21.5dBm at 900MHz, Integrated LO Quadrature Generator LT5517 40MHz to 900MHz Direct Conversion Quadrature Demodulator High IIP3: 21dBm at 800MHz, Integrated LO Quadrature Generator LT5522 600MHz to 2.7GHz High Linearity Downconverting Mixer 4.5V to 5.25V Supply, 25dBm IIP3 at 900MHz, NF = 12.5dB, 50Ω Single-Ended RF and LO Ports 2229fa LT 0106 REV A • PRINTED IN USA 24 Linear Technology Corporation 1630 McCarthy Blvd., Milpitas, CA 95035-7417 (408) 432-1900 ● FAX: (408) 434-0507 ● www.linear.com © LINEAR TECHNOLOGY CORPORATION 2004
