Datasheet LT3013B (Analog Devices) - 2
Description250mA, 4V to 80V Low Dropout Micropower Linear Regulator with PWRGD
Pages / Page16 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION. …
File Format / SizePDF / 178 Kb
ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION. LEAD FREE FINISH. TAPE AND REEL. PART MARKING
ABSOLUTE MAXIMUM RATINGS (Note 1) PIN CONFIGURATION ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING
LT3013B
IN Pin Voltage .. ±80V Storage Temperature Range OUT Pin Voltage ... ±60V TSSOP Package .. –65°C to 150°C IN to OUT Differential Voltage .. ±80V DFN Package ... –65°C to 125°C ADJ Pin Voltage ... ±7V Operating Junction Temperature Range CT Pin Voltage ... 7V, –0.5V (Notes 3, 9, 10) ... –40°C to 125°C PWRGD Pin Voltage .. 80V, –0.5V Lead Temperature (Soldering, 10 sec) Output Short-Circuit Duration ... Indefi nite TSSOP Only ... 300°C
PIN CONFIGURATION
TOP VIEW TOP VIEW GND 1 16 GND NC 1 12 NC NC 2 15 NC OUT 2 11 IN OUT 3 14 IN OUT 3 10 IN OUT 4 13 IN 13 17 ADJ 4 9 NC ADJ 5 12 NC GND 5 8 NC GND 6 11 NC PWRGD 6 7 C PWRGD 7 10 C T T GND 8 9 GND DE PACKAGE 12-LEAD (4mm s 3mm) PLASTIC DFN FE PACKAGE T 16-LEAD PLASTIC TSSOP JMAX = 125°C, θJA = 40°C/W, θJC = 16°C/W EXPOSED PAD (PIN 13) IS GND, MUST BE SOLDERED TO PCB TJMAX = 125°C, θJA = 40°C/W, θJC = 16°C/W EXPOSED PAD (PIN 17) IS GND, MUST BE SOLDERED TO PCB
ORDER INFORMATION LEAD FREE FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LT3013BEDE#PBF LT3013BEDE#TRPBF 3013B 12-Lead (4mm × 3mm) Plastic DFN –40°C to 125°C LT3013BEFE#PBF LT3013BEFE#TRPBF 3013BEFE 16-Lead Plastic TSSOP –40°C to 125°C
LEAD BASED FINISH TAPE AND REEL PART MARKING PACKAGE DESCRIPTION TEMPERATURE RANGE
LT3013BEDE LT3013BEDE#TR 3013B 12-Lead (4mm × 3mm) Plastic DFN –40°C to 125°C LT3013BEFE LT3013BEFE#TR 3013BEFE 16-Lead Plastic TSSOP –40°C to 125°C Consult LTC Marketing for parts specifi ed with wider operating temperature ranges. For more information on lead free part marking, go to: http://www.linear.com/leadfree/ For more information on tape and reel specifi cations, go to: http://www.linear.com/tapeandreel/ 3013bfb 2
