Datasheet LT3085 (Analog Devices) - 19
DescriptionAdjustable 500mA Single Resistor Low Dropout Regulator
Pages / Page28 / 19 — TYPICAL APPLICATIONS. Adding Shutdown. Low Dropout Voltage LED Driver. …
File Format / SizePDF / 304 Kb
TYPICAL APPLICATIONS. Adding Shutdown. Low Dropout Voltage LED Driver. Using a Lower Value SET Resistor
TYPICAL APPLICATIONS Adding Shutdown Low Dropout Voltage LED Driver Using a Lower Value SET Resistor
LT3085
VIN IN LT3085 VIN C1 VCONTROL D1 100mA LT3085 IN VCONTROL + – OUT + VOUT – 3085 TA04 SET OUT Q1 Q2* ON OFF R1 SET VN2222LL VN2222LL R1 R2 24.9k 2.49Ω SHUTDOWN 3085 TA05 Q2 INSURES ZERO OUTPUT * IN THE ABSENCE OF ANY OUTPUT LOAD.
V IN LT3085 IN 12V VCONTROL + – C1 OUT VOUT 1μF 0.5V TO 10V SET VOUT = 0.5V + 1mA • RSET R1 R2 49.9k 1mA C 499Ω OUT 4.7μF 1% 1% RSET 10k 3085 TA06 3085fb 19 Document Outline FEATURES DESCRIPTION APPLICATIONS TYPICAL APPLICATION ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION ORDER INFORMATION ELECTRICAL CHARACTERISTICS TYPICAL PERFORMANCE CHARACTERISTICS PIN FUNCTIONS BLOCK DIAGRAM APPLICATIONS INFORMATION TYPICAL APPLICATIONS PACKAGE DESCRIPTION REVISION HISTORY TYPICAL APPLICATION RELATED PARTS
