Datasheet AD7091R (Analog Devices) - 22
Description | 1 MSPS, Ultralow Power, 12-Bit ADC in 10-Lead LFCSP and MSOP |
Pages / Page | 22 / 22 — AD7091R. Data Sheet. OUTLINE DIMENSIONS. 2.54. 3.10. 2.44. 3.00. 2.34. … |
Revision | B |
File Format / Size | PDF / 595 Kb |
AD7091R. Data Sheet. OUTLINE DIMENSIONS. 2.54. 3.10. 2.44. 3.00. 2.34. 0.50 BSC. 2.90. 2.10. 1.00. 2.00. 0.35. EXPOSED. PIN 1 INDEX. 0.90. PAD. AREA. 1.90
AD7091R Data Sheet OUTLINE DIMENSIONS 2.54 3.10 2.44 3.00 2.34 0.50 BSC 2.90 6 10 2.10 1.00 2.00 0.35 EXPOSED PIN 1 INDEX 0.90 PAD AREA 1.90 0.30 0.80 0.25 5 1 PIN 1 TOP VIEW BOTTOM VIEW INDICATOR (R 0.15) 0.80 0.75 0.05 MAX 0.70 0.02 NOM FOR PROPER CONNECTION OF THE EXPOSED PAD, REFER TO THE PIN CONFIGURATION AND SEATING 0.30 FUNCTION DESCRIPTIONS PLANE 0.25 0.203 REF SECTION OF THIS DATA SHEET. 0.20 B 6-2010- COMPLIANT TO JEDEC STANDARDS MO-229-WCED-3 05-0
Figure 32. 10-Lead Lead Frame Chip Scale Package [LFCSP_WD] 3 mm × 2 mm Body, Very Very Thin, Dual Lead (CP-10-12) Dimensions shown in millimeters
3.10 3.00 2.90 10 6 5.15 3.10 4.90 3.00 4.65 1 2.90 5 PIN 1 IDENTIFIER 0.50 BSC 0.95 15° MAX 0.85 1.10 MAX 0.75 0.70 0.15 6° 0.23 0.55 0.30 0.05 0° 0.13 0.40 0.15 COPLANARITY 0.10 COMPLIANT TO JEDEC STANDARDS MO-187-BA 091709-A
Figure 33. 10-Lead Mini Small Outline Package [MSOP] (RM-10) Dimensions shown in millimeters
ORDERING GUIDE Model1 Temperature Range Package Description Package Option Branding
AD7091RBCPZ-RL −40°C to +125°C 10-Lead Lead Frame Chip Scale Package [LFCSP_WD] CP-10-12 C7P AD7091RBCPZ-RL7 −40°C to +125°C 10-Lead Lead Frame Chip Scale Package [LFCSP_WD] CP-10-12 C7P AD7091RBRMZ −40°C to +125°C 10-Lead Mini Small Outline Package [MSOP] RM-10 DRQ AD7091RBRMZ-RL7 −40°C to +125°C 10-Lead Mini Small Outline Package [MSOP] RM-10 DRQ EVAL-AD7091RSDZ Evaluation Board EVAL-SDP-CB1Z Evaluation Controller Board 1 Z = RoHS Compliant Part.
©2012–2016 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. D10494-0-9/16(B)
Rev. B | Page 20 of 20 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION CIRCUIT INFORMATION CONVERTER OPERATION ADC TRANSFER FUNCTION INTERNAL/EXTERNAL VOLTAGE REFERENCE TYPICAL CONNECTION DIAGRAM ANALOG INPUT MODES OF OPERATION Normal Mode Power-Down Mode POWER CONSUMPTION Normal Mode Normal and Power-Down Mode Combination SERIAL INTERFACE WITH BUSY INDICATOR WITHOUT BUSY INDICATOR SOFTWARE RESET INTERFACING WITH 8-/16-BIT SPI OUTLINE DIMENSIONS ORDERING GUIDE
