Datasheet AD9268 (Analog Devices) - 2
Description16-Bit, 125 MSPS/105 MSPS/80 MSPS, 1.8 V Dual Analog-to-Digital Converter
Pages / Page45 / 2 — AD9268* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017. …
RevisionA
AD9268* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017. COMPARABLE PARTS. TOOLS AND SIMULATIONS. EVALUATION KITS
AD9268* PRODUCT PAGE QUICK LINKS Last Content Update: 09/27/2017 COMPARABLE PARTS TOOLS AND SIMULATIONS EVALUATION KITS
View a parametric search of comparable parts. • Visual Analog • AD9268 IBIS Models
EVALUATION KITS
• AD9268 Evaluation Board
REFERENCE DESIGNS
• CN0171
DOCUMENTATION Application Notes REFERENCE MATERIALS
• AN-1142: Techniques for High Speed ADC PCB Layout
Solutions Bulletins & Brochures
• AN-1211: Powering the AD9268 Dual Channel 16-Bit, 125 • Test & Instrumentation Solutions Bulletin, Volume 10, MSPS Analog-to-Digital Converter with the ADP2114 Issue 3 Synchronous Step-Down DC-to-DC Regulator for
Technical Articles
Increased Efficiency • Improve The Design Of Your Passive Wideband ADC • AN-586: LVDS Outputs for High Speed A/D Converters Front-End Network • AN-742: Frequency Domain Response of Switched- • MS-2210: Designing Power Supplies for High Speed ADC Capacitor ADCs • AN-807: Multicarrier WCDMA Feasibility
DESIGN RESOURCES
• AN-808: Multicarrier CDMA2000 Feasibility • AD9268 Material Declaration • AN-812: MicroController-Based Serial Port Interface (SPI) • PCN-PDN Information Boot Circuit • Quality And Reliability • AN-827: A Resonant Approach to Interfacing Amplifiers to Switched-Capacitor ADCs • Symbols and Footprints • AN-878: High Speed ADC SPI Control Software
DISCUSSIONS
• AN-905: Visual Analog Converter Evaluation Tool Version 1.0 User Manual View all AD9268 EngineerZone Discussions. • AN-935: Designing an ADC Transformer-Coupled Front End
SAMPLE AND BUY Data Sheet
Visit the product page to see pricing options. • AD9268: 16-Bit, 80 MSPS/105 MSPS/125 MSPS, 1.8 V Dual Analog-to-Digital Converter (ADC) Data Sheet
TECHNICAL SUPPORT User Guides
Submit a technical question or find your regional support • UG-003: Evaluating the AD9650/AD9268/AD9258/ number. AD9251/AD9231/AD9204 Analog-to-Digital Converters
DOCUMENT FEEDBACK
Submit feedback for this data sheet.
This page is dynamically generated by Analog Devices, Inc., and inserted into this data sheet. A dynamic change to the content on this page will not trigger a change to either the revision number or the content of the product data sheet. This dynamic page may be frequently modified.
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM PRODUCT HIGHLIGHTS TABLE OF CONTENTS REVISION HISTORY GENERAL DESCRIPTION SPECIFICATIONS ADC DC SPECIFICATIONS ADC AC SPECIFICATIONS DIGITAL SPECIFICATIONS SWITCHING SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL CHARACTERISTICS ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS EQUIVALENT CIRCUITS THEORY OF OPERATION ADC ARCHITECTURE ANALOG INPUT CONSIDERATIONS Input Common Mode Common-Mode Voltage Servo Dither Differential Input Configurations VOLTAGE REFERENCE Internal Reference Connection External Reference Operation CLOCK INPUT CONSIDERATIONS Clock Input Options Input Clock Divider Clock Duty Cycle Jitter Considerations CHANNEL/CHIP SYNCHRONIZATION POWER DISSIPATION AND STANDBY MODE DIGITAL OUTPUTS Digital Output Enable Function (OEB) TIMING Data Clock Output (DCO) BUILT-IN SELF-TEST (BIST) AND OUTPUT TEST BUILT-IN SELF-TEST (BIST) OUTPUT TEST MODES SERIAL PORT INTERFACE (SPI) CONFIGURATION USING THE SPI HARDWARE INTERFACE CONFIGURATION WITHOUT THE SPI SPI ACCESSIBLE FEATURES MEMORY MAP READING THE MEMORY MAP REGISTER TABLE Open Locations Default Values Logic Levels Transfer Register Map Channel-Specific Registers MEMORY MAP REGISTER TABLE MEMORY MAP REGISTER DESCRIPTIONS Sync Control (Register 0x100) Bits[7:3]—Reserved Bit 2—Clock Divider Next Sync Only Bit 1—Clock Divider Sync Enable Bit 0—Master Sync Enable APPLICATIONS INFORMATION DESIGN GUIDELINES Power and Ground Recommendations LVDS Operation Exposed Paddle Thermal Heat Slug Recommendations VCM RBIAS Reference Decoupling SPI Port OUTLINE DIMENSIONS ORDERING GUIDE
