Datasheet AD6645 (Analog Devices) - 17
Description14-Bit, 80 MSPS/105 MSPS A/D Converter
Pages / Page25 / 17 — AD6645. Data Sheet. Spurious-Free Dynamic Range (SFDR). Two-Tone SFDR. …
RevisionE
AD6645. Data Sheet. Spurious-Free Dynamic Range (SFDR). Two-Tone SFDR. Two-Tone Intermodulation Distortion Rejection
AD6645 Data Sheet Spurious-Free Dynamic Range (SFDR) Two-Tone SFDR Two-Tone Intermodulation Distortion Rejection
The ratio of the rms signal amplitude to the rms value of the The ratio of the rms value of either input tone to the rms value peak spurious spectral component. The peak spurious component of the peak spurious component. The peak spurious component may or may not be a harmonic. May be reported in dBc (that is, may or may not be an IMD product, and may be reported in degrades as signal level is lowered) or dBFS (always related back dBc (that is, degrades as signal level is lowered) or in dBFS to converter full scale). (always related back to converter ful scale).
Two-Tone Intermodulation Distortion Rejection Worst Other Spur
The ratio of the rms value of either input tone to the rms value The ratio of the rms signal amplitude to the rms value of the of the worst third-order intermodulation product, reported in dBc. worst spurious component (excluding the second and third harmonics), reported in dBc. Rev. E | Page 16 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PRODUCT HIGHLIGHTS FUNCTIONAL BLOCK DIAGRAM REVISION HISTORY SPECIFICATIONS DC SPECIFICATIONS DIGITAL SPECIFICATIONS AC SPECIFICATIONS SWITCHING SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE EXPLANATION OF TEST LEVELS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS EQUIVALENT CIRCUITS TERMINOLOGY THEORY OF OPERATION APPLYING THE AD6645 Encoding the AD6645 Driving the Analog Inputs Power Supplies Digital Outputs Grounding LAYOUT INFORMATION JITTER CONSIDERATIONS OUTLINE DIMENSIONS ORDERING GUIDE
