Datasheet AD8132 (Analog Devices) - 9
DescriptionLow Cost, High Speed Differential Amplifier
Pages / Page33 / 9 — AD8132. ±DIN TO ±OUT SPECIFICATIONS. Table 5. Parameter Conditions. Min. …
RevisionI
File Format / SizePDF / 518 Kb
AD8132. ±DIN TO ±OUT SPECIFICATIONS. Table 5. Parameter Conditions. Min. Typ. Max. Unit. VOCM TO ±OUT SPECIFICATIONS
AD8132 ±DIN TO ±OUT SPECIFICATIONS Table 5 Parameter Conditions Min Typ Max Unit VOCM TO ±OUT SPECIFICATIONS
link to page 21 link to page 21 link to page 21 link to page 21
At TA = 25°C, VS = 3 V, VOCM = 1.5 V, G = +1, RL, dm = 499 Ω, RF = RG = 348 Ω, unless otherwise noted. For G = +2, RL, dm = 200 Ω, RF = 1000 Ω, RG = 499 Ω. Refer to Figure 56 and Figure 57 for test setup and label descriptions. All specifications refer to single-ended input and differential outputs, unless otherwise noted.
Table 5. Parameter Conditions Min Typ Max Unit
DYNAMIC PERFORMANCE −3 dB Large Signal Bandwidth VOUT = 1 V p-p 350 MHz VOUT = 1 V p-p, G = +2 165 MHz −3 dB Small Signal Bandwidth VOUT = 0.2 V p-p 350 MHz VOUT = 0.2 V p-p, G = +2 150 MHz Bandwidth for 0.1 dB Flatness VOUT = 0.2 V p-p 45 MHz VOUT = 0.2 V p-p, G = +2 50 MHz NOISE/HARMONIC PERFORMANCE Second Harmonic VOUT = 1 V p-p, 1 MHz, RL, dm = 800 Ω −100 dBc VOUT = 1 V p-p, 5 MHz, RL, dm = 800 Ω −94 dBc VOUT = 1 V p-p, 20 MHz, RL, dm = 800 Ω −77 dBc Third Harmonic VOUT = 1 V p-p, 1 MHz, RL, dm = 800 Ω −90 dBc VOUT = 1 V p-p, 5 MHz, RL, dm = 800 Ω −85 dBc VOUT = 1 V p-p, 20 MHz, RL, dm = 800 Ω −66 dBc INPUT CHARACTERISTICS Offset Voltage (RTI) VOS, dm = VOUT, dm/2; VDIN+ = VDIN− = VOCM = 1.5 V ±10 mV Input Bias Current 3 μA Input Common-Mode Voltage 0.3 to 1.0 V CMRR ΔVOUT, dm/ΔVIN, cm; ΔVIN, cm = ±0.5 V; resistors matched to 0.01% −60 dB
Table 6. Parameter Conditions Min Typ Max Unit
DC PERFORMANCE Input Offset Voltage VOS, cm = VOUT, cm; VDIN+ = VDIN− = VOCM = 1.5 V ±7 mV Gain ΔVOUT, cm/ΔVOCM; ΔVOCM = ±0.5 V 1 V/V POWER SUPPLY Operating Range 2.7 11 V Quiescent Current VDIN+ = VDIN− = VOCM = 0 V 7.25 mA Power Supply Rejection Ratio ΔVOUT, dm/ΔVS; ΔVS = ±0.5 V −70 dB OPERATING TEMPERATURE RANGE −40 +125 °C Rev. I | Page 8 of 32 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION CONNECTION DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ±DIN TO ±OUT SPECIFICATIONS VOCM TO ±OUT SPECIFICATIONS ±DIN TO ±OUT SPECIFICATIONS VOCM TO ±OUT SPECIFICATIONS ±DIN TO ±OUT SPECIFICATIONS VOCM TO ±OUT SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE MAXIMUM POWER DISSIPATION ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS TEST CIRCUITS OPERATIONAL DESCRIPTION DEFINITION OF TERMS Differential Voltage Common-Mode Voltage BASIC CIRCUIT OPERATION THEORY OF OPERATION GENERAL USAGE OF THE AD8132 DIFFERENTIAL AMPLIFIER WITHOUT RESISTORS (HIGH INPUT IMPEDANCE INVERTING AMPLIFIER) OTHER β2 = 1 CIRCUITS VARYING β2 β1 = 0 ESTIMATING THE OUTPUT NOISE VOLTAGE CALCULATING INPUT IMPEDANCE OF THE APPLICATION CIRCUIT INPUT COMMON-MODE VOLTAGE RANGE IN SINGLE-SUPPLY APPLICATIONS SETTING THE OUTPUT COMMON-MODE VOLTAGE DRIVING A CAPACITIVE LOAD OPEN-LOOP GAIN AND PHASE LAYOUT, GROUNDING, AND BYPASSING CIRCUITS APPLICATIONS INFORMATION ANALOG-TO-DIGITAL DRIVER BALANCED CABLE DRIVER TRANSMIT EQUALIZER LOW-PASS DIFFERENTIAL FILTER HIGH COMMON-MODE OUTPUT IMPEDANCE AMPLIFIER FULL-WAVE RECTIFIER AUTOMOTIVE PRODUCTS OUTLINE DIMENSIONS ORDERING GUIDE
