Datasheet LTC4300A-3 (Analog Devices) - 14
DescriptionLevel Shifting Hot Swappable 2-Wire Bus Buffer with Enable
Pages / Page14 / 14 — Typical applicaTion. Figure 5. 5V to 3.3V Level Translator. relaTeD parTs …
File Format / SizePDF / 216 Kb
Typical applicaTion. Figure 5. 5V to 3.3V Level Translator. relaTeD parTs PART NUMBER. DESCRIPTION. COMMENTS
Typical applicaTion Figure 5 5V to 3.3V Level Translator relaTeD parTs PART NUMBER DESCRIPTION COMMENTS
LTC4300A-3
Typical applicaTion
VCC CARD_VCC, 3.3V 5V C2 C1 R3 R2 R1 R4 0.01µF 0.01µF 10k 10k 10k 10k V SDA CC V SDAIN CC2 SDAOUT CARD_SDA SCL SCLIN LTC4300A-3 SCLOUT CARD_SCL 4300A-3 F05 ENABLE GND
Figure 5. 5V to 3.3V Level Translator relaTeD parTs PART NUMBER DESCRIPTION COMMENTS
LTC1380/LTC1393 Single-Ended 8-Channel/Differential 4-Channel Low RON: 35Ω Single-Ended/70Ω Differential, Expandable to 32 Single or Analog Mux with SMBus Interface 16 Differential Channels LTC1427-50 Micropower, 10-Bit Current Output DAC with SMBus Precision 50µA ± 2.5% Tolerance Over Temperature, 4 Selectable SMBus Interface Addresses, DAC Powers Up at Zero or Mid-Scale LTC1623 Dual High Side Switch Controller with SMBus 8 Selectable Addresses/16-Channel Capability Interface LTC1663 SMBus Interface 10-Bit Rail-to-Rail Micropower DAC DNL < 0.75LSB Max, 5-Lead SOT-23 Package LTC1694/LTC1694-1 SMBus Accelerator Improved SMBus/I2C Rise Time, Ensures Data Integrity with Multiple SMBus/I2C Devices LT1786F SMBus Controlled CCFL Switching Regulator 1.25A, 200kHz, Floating or Grounded Lamp Configurations LTC1695 SMBus/I2C Fan Speed Controller in ThinSOT™ 0.75Ω PMOS 180mA Regulator, 6-Bit DAC LTC1840 Dual I2C Fan Speed Controller Two 100µA 8-Bit DACs, Two Tach Inputs, Four GPI0 LTC4300A-1/ Hot Swappable 2-Wire Bus Buffer Preserves Data Integrity Under Hot Swap Conditions, Provides Capacitive LTC4300A-2 Buffering, Rise Time Acceleration LTC4301 Supply Independent 2-Wire Bus Buffer Provides Capacitive Buffer, 3.3V to 5V Level Translation with Only the Card Bus VCC Supply LTC4301L Hot-Swappable 2-Wire Bus Buffer with Low Voltage Level Translators, 1V Signals to Standard 3.3V and 5V Logic Rails Level Translation LTC4302-1/ Addressable I2C and SMBus Compatible Bus Buffers Provides Capacitive Buffering, Rise time Acceleration, and Input to Output LTC4302-2 Connection Control Using 2-Wire Bus Commands 4300a3fa 14 Linear Technology Corporation LT 0912 REV A • PRINTED IN USA 1630 McCarthy Blvd., Milpitas, CA 95035-7417 (408) 432-1900 ● FAX: (408) 434-0507 ● www.linear.com LINEAR TECHNOLOGY CORPORATION 2004 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Package Description Revision History Related Parts Typical Application
