Datasheet LTC4317 (Analog Devices) - 16
| Description | Dual I2C/SMBus Address Translator |
| Pages / Page | 16 / 16 — Typical applicaTion. Figure 11. Comparison Between … |
| File Format / Size | PDF / 229 Kb |
Typical applicaTion. Figure 11. Comparison Between LTC4316/LTC4317/LTC4318. relaTeD parTs PART NUMBER DESCRIPTION. COMMENTS
LTC4317
Typical applicaTion
SINGLE “Y” CONNECTED DUAL DUAL LTC4316 LTC4317 LTC4318 VCC VCC VCC SCLIN SCLIN SCLOUT SCLOUT SCLIN SCLIN SCLOUT SCLOUT1 SCLIN1 SCLIN SCLOUT SCLOUT1 SDAIN SDAIN SDAOUT SDAOUT SDAIN SDAIN SDAOUT SDAOUT1 SDAIN1 SDAIN SDAOUT SDAOUT1 XORH XORH READY READY XORH1 XORH READY READY1 XORH1 XORH READY READY1 XORL XORL XORL1 XORL XORL1 XORL ENABLE ENABLE ENABLE1 ENABLE ENABLE1 ENABLE CHANNEL1 CHANNEL1 GND SCLIN SCLOUT SCLOUT2 SCLIN2 SCLIN SCLOUT SCLOUT2 SDAIN SDAOUT SDAOUT2 SDAIN2 SDAIN SDAOUT SDAOUT2 XORH2 XORH READY READY2 XORH2 XORH READY READY2 XORL2 XORL XORL2 XORL ENABLE2 ENABLE ENABLE2 ENABLE CHANNEL2 CHANNEL2 GND GND 4317 F11
Figure 11. Comparison Between LTC4316/LTC4317/LTC4318 relaTeD parTs PART NUMBER DESCRIPTION COMMENTS
LTC4300A-1/ Hot Swappable 2-Wire Bus Buffers LTC4300A-1: Bus Buffer with READY and ENABLE LTC4300A-2/ LTC4300A-2: Dual Supply Buffer with ACC LTC4300A-3 LTC4300A-3: Dual Supply Buffer and ENABLE LTC4302-1/ Addressable 2-Wire Bus Buffer Address Expansion, GPIO, Software Controlled LTC4302-2 LTC4303/ Hot Swappable 2-Wire Bus Buffer with Stuck Provides Automatic Clocking to Free Stuck I2C Busses LTC4304 Bus Recovery LTC4305/ 2- or 4-Channel, 2-Wire Bus Multiplexers Two or Four Software Selectable Downstream Busses, Stuck Bus Disconnect, Rise Time LTC4306 with Capacitance Buffering Accelerators, Fault Reporting, ±10kV HBM ESD LTC4307 Low Offset, Hot Swappable 2-Wire Bus 60mV Buffer Offset, 30ms Stuck Bus Disconnect and Recovery, Rise Time Accelerators, Buffer with Stuck Bus Recovery ±5kV HBM ESD LTC4307-1 High Definition Multimedia Interface (HDMI) 60mV Buffer Offset, 3.3V to 5V Level Shifting, ±5kV HBM ESD Level Shifting 2-Wire Bus Buffer LTC4308 Low Voltage, Level Shifting Hot Swappable Bus Buffer with 1V Precharge, ENABLE and READY, 0.9V to 5.5V Level Translation, 30ms 2-Wire Bus Buffer with Stuck Bus Recovery Stuck Bus Disconnect and Recovery, Output Side Rise Time Accelerators, ±6kV HBM ESD LTC4309 Low Offset Hot Swappable 2-Wire Bus 60mV Buffer Offset, 30ms Stuck Bus Disconnect and Recovery, Rise Time Accelerators, Buffer with Stuck Bus Recovery ±5kV HBM ESD, 1.8V to 5.5V Level Translation LTC4310-1/ Hot Swappable I2C Isolators Bidirectional I2C Communication Between Two Isolated Busses, LTC4310-1: 100kHz Bus, LTC4310-2 LTC4310-2: 400kHz Bus LTC4311 Hot Swappable I2C/SMBus Accelerator Rise Time Acceleration with ENABLE, ±8kV HBM ESD LTC4312/ 2- or 4-Channel, Hardware Selectable 2-Wire Two or Four Pin Selectable Downstream Busses, VIL Up to 0.3V • VCC, Rise Time LTC4314 Bus Multiplexers with Capacitance Buffering Accelerators, 45ms Stuck Bus Disconnect and Recovery, ±4kV HBM ESD LTC4313-1/ High Noise Margin 2-Wire Bus Buffers VIL = 0.3V • VCC, Rise Time Accelerators, Stuck Bus Disconnect and Recovery, 1V LTC4313-2/ Precharge, ±4kV HBM ESD LTC4313-3 4317fa 16 LT 1015, • PRINTED IN USA Linear Technology Corporation 1630 McCarthy Blvd., Milpitas, CA 95Fo 0 r3 m 5- o7re 4 in 17formation www.linear.com/LTC4317 (408) 432-1900 ● FAX: (408) 434-0507 ● www.linear.com/LTC4317 © LINEAR TECHNOLOGY CORPORATION 2015 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Timing Diagram Typical Performance Characteristics Pin Functions Block Diagram Operation Typical Applications Package Description Revision History Typical Application Related Parts
