Datasheet LTC5564 (Analog Devices) - 16
DescriptionUltraFast 7ns Response Time 15GHz RF Power Detector with Comparator
Pages / Page16 / 16 — TYPICAL APPLICATION. 600MHz to 15GHz RF Power Detector. RELATED PARTS …
File Format / SizePDF / 475 Kb
TYPICAL APPLICATION. 600MHz to 15GHz RF Power Detector. RELATED PARTS PART NUMBER DESCRIPTION. COMMENTS
TYPICAL APPLICATION 600MHz to 15GHz RF Power Detector RELATED PARTS PART NUMBER DESCRIPTION COMMENTS
LTC5564
33pF RF INPUT RFIN VOUTADJ VCCA VOUT VCC VCCRF LTC5564 1000pF 10pF VCCP GND G1 VCOMP LEN VREF G0 + µC 5564 TA02
RELATED PARTS PART NUMBER DESCRIPTION COMMENTS Schottky Peak Detectors
LTC5505 RF Power Detectors with >40dB Dynamic Range 300MHz to 3GHz, Temperature Compensated, 2.7V to 6V Supply LTC5507 100kHz to 1000MHz RF Power Detector 100kHz to 1GHz, Temperature Compensated, 2.7V to 6V Supply LTC5508 300MHz to 7GHz RF Power Detector 44dB Dynamic Range, Temperature Compensated, SC70 Package LTC5509 300MHz to 3GHz RF Power Detector 36dB Dynamic Range, Low Power Consumption, SC70 Package LTC5530 300MHz to 7GHz Precision RF Power Detector Precision VOUT Offset Control, Shutdown, Adjustable Gain LTC5531 300MHz to 7GHz Precision RF Power Detector Precision VOUT Offset Control, Shutdown, Adjustable Offset LTC5532 300MHz to 7GHz Precision RF Power Detector Precision VOUT Offset Control, Adjustable Gain and Offset LTC5536 Precision 600MHz to 7GHz RF Power Detector 25ns Response Time, Comparator Reference Input, Latch Enable Input, with Fast Comparator Output –26dBm to +12dBm Input Range
RF Log Detectors
LT5534 50MHz to 3GHz Log RF Power Detector with ±1dB Output Variation Over Temperature, 38ns Response Time, 60dB Dynamic Range Log Linear Response LT®5537 Wide Dynamic Range Log RF/IF Detector Low Frequency to 1GHz, 83dB Log Linear Dynamic Range LT5538 75dB Dynamic Range 3.8GHz Log RF Power Detector ±0.8dB Accuracy Over Temperature
RMS Detectors
LT5570 60dB Dynamic Range RMS Detector 40MHz to 2.7GHz, ±0.5dB Accuracy Over Temperature LT5581 6GHz RMS Power Detector, 40dB Dynamic Range ±1dB Accuracy Over Temperature, Log Linear Response, 1.4mA at 3.3V LTC5587 10MHz to 6GHz RMS Detector with Digitized Output 40dB Dynamic Detection Range, Integrated 12-Bit Serial Output ADC, ±1dB Accuracy Over Temperature LTC5582 10GHz, 57dB Dynamic Range RMS Detector 40MHz to 10GHz Operation, ±0.5dB Linearity Single-Ended RF Output— Requires No External Balun Transformer LTC5583 6GHz, Matched Dual RMS Detector Measures VSWR Up to 60dB Dynamic Range, ±0.5dB Accuracy Over Temperature, 40dB Channel-to-Channel Isolation with Single-Ended RF Inputs 5564fc 16 LT 0115 REV C • PRINTED IN USA Linear Technology Corporation 1630 McCarthy Blvd., Milpitas, CA 95Fo 0 r3 m 5- o7re 4 in 17formation www.linear.com/LTC5564 (408) 432-1900 ● FAX: (408) 434-0507 ● www.linear.com/LTC5564 LINEAR TECHNOLOGY CORPORATION 2010 Document Outline Features Description Applications Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Typical Performance Characteristics Pin Functions Simplified Block Diagram Applications Information Revision History Typical Application Related Parts
