Datasheet ADXL354, ADXL355 (Analog Devices) - 42
| Description | Low Noise, Low Drift, Low Power 3-Axis Accelerometer with digital output |
| Pages / Page | 42 / 42 — ADXL354/ADXL355. Data Sheet. PACKAGING AND ORDERING INFORMATION OUTLINE … |
| Revision | A |
| File Format / Size | PDF / 1.6 Mb |
ADXL354/ADXL355. Data Sheet. PACKAGING AND ORDERING INFORMATION OUTLINE DIMENSIONS. DETAIL A. 0.80. 6.25. 2.25. BSC. 6.00 SQ. 2.05
ADXL354/ADXL355 Data Sheet PACKAGING AND ORDERING INFORMATION OUTLINE DIMENSIONS DETAIL A 0.80 6.25 2.25 BSC 6.00 SQ 2.05 1.674 BSC 5.85 1.85 0.510 REF 0.30 SQ 12 14 (PIN 1 INDEX) 11 1 DETAIL A 5.60 3.81 R 0.103 SQ REF (14 PLCS) 0.508 BSC 8 4 7 5 R 0.25 TOP VIEW SIDE VIEW BOTTOM VIEW 0.914 (4 PLCS) 0.15 0.10 BSC 2.54 REF BSC BSC 2.20 REF R 0.203 B (14 PLCS) 54 2016- 045 -0 27- G K P 05-
Figure 77. 14-Terminal Ceramic Leadless Chip Carrier [LCC] (E-14-1) Dimensions shown in millimeters
BRANDING INFORMATION NO BRAND ON THIS LINE PIN ONE LOCATOR, NO OTHER BRAND ON THIS LINE PART NUMBER ADXL354B, ADXL354C, OR ADXL355B #YYWW TWO DIGIT YEAR, TWO DIGIT WEEK ID
8
6 DIGIT LOT NUMBER SIX DIGIT LOT NUMBER
07 5- 420 1 Figure 78. Branding Information
ORDERING GUIDE Output Measurement Specified Package Model1 Mode Range (g ) Voltage (V) Temperature Range Package Description Option
ADXL354BEZ Analog ±2, ±4 3.3 −40°C to +125°C 14-Terminal LCC E-14-1 ADXL354BEZ-RL Analog ±2, ±4 3.3 −40°C to +125°C 14-Terminal LCC E-14-1 ADXL354BEZ-RL7 Analog ±2, ±4 3.3 −40°C to +125°C 14-Terminal LCC E-14-1 ADXL354CEZ Analog ±2, ±8 3.3 −40°C to +125°C 14-Terminal LCC E-14-1 ADXL354CEZ-RL Analog ±2, ±8 3.3 −40°C to +125°C 14-Terminal LCC E-14-1 ADXL354CEZ-RL7 Analog ±2, ±8 3.3 −40°C to +125°C 14-Terminal LCC E-14-1 ADXL355BEZ Digital ±2.048, ±4.096, 3.3 −40°C to +125°C 14-Terminal LCC E-14-1 ±8.192 ADXL355BEZ-RL Digital ±2.048, ±4.096, 3.3 −40°C to +125°C 14-Terminal LCC E-14-1 ±8.192 ADXL355BEZ-RL7 Digital ±2.048, ±4.096, 3.3 −40°C to +125°C 14-Terminal LCC E-14-1 ±8.192 EVAL-ADXL354BZ Evaluation Board for ADXL354BEZ EVAL-ADXL354CZ Evaluation Board for ADXL354CEZ EVAL-ADXL355Z Evaluation Board for ADXL355BEZ 1 Z = RoHS-Compliant Part.
©2016 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. D14205-0-9/16(0)
Rev. 0 | Page 42 of 42 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ANALOG OUTPUT FOR THE ADXL354 DIGITAL OUTPUT FOR THE ADXL355 SPI DIGITAL INTERFACE CHARACTERISTICS FOR THE ADXL355 I2C DIGITAL INTERFACE CHARACTERISTICS FOR THE ADXL355 ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS ROOT ALLAN VARIANCE (RAV) ADXL355 CHARACTERISTICS THEORY OF OPERATION ANALOG OUTPUT DIGITAL OUTPUT AXES OF ACCELERATION SENSITIVITY POWER SEQUENCING POWER SUPPLY DESCRIPTION VSUPPLY V1P8ANA V1P8DIG VDDIO OVERRANGE PROTECTION SELF TEST FILTER SERIAL COMMUNICATIONS SPI PROTOCOL I2C PROTOCOL READING ACCELERATION OR TEMPERATURE DATA FROM THE INTERFACE FIFO INTERRUPTS DATA_RDY DRDY PIN FIFO_FULL FIFO_OVR ACTIVITY NVM_BUSY EXTERNAL SYNCHRONIZATION AND INTERPOLATION EXT_SYNC = 00—No External Sync or Interpolation EXT_SYNC = 10—External Sync with Interpolation EXT_SYNC = 01—External Sync and External Clock ADXL355 REGISTER MAP REGISTER DEFINITIONS ANALOG DEVICES ID REGISTER Address: 0x00, Reset: 0xAD, Name: DEVID_AD ANALOG DEVICES MEMS ID REGISTER Address: 0x01, Reset: 0x1D, Name: DEVID_MST DEVICE ID REGISTER Address: 0x02, Reset: 0xED, Name: PARTID PRODUCT REVISION ID REGISTER Address: 0x03, Reset: 0x00, Name: REVID STATUS REGISTER Address: 0x04, Reset: 0x00, Name: STATUS FIFO ENTRIES REGISTER Address: 0x05, Reset: 0x00, Name: FIFO_ENTRIES TEMPERATURE DATA REGISTERS Address: 0x06, Reset: 0x00, Name: TEMP2 Address: 0x07, Reset: 0x00, Name: TEMP1 X-AXIS DATA REGISTERS Address: 0x08, Reset: 0x00, Name: XDATA3 Address: 0x09, Reset: 0x00, Name: XDATA2 Address: 0x0A, Reset: 0x00, Name: XDATA1 Y-AXIS DATA REGISTERS Address: 0x0B, Reset: 0x00, Name: YDATA3 Address: 0x0C, Reset: 0x00, Name: YDATA2 Address: 0x0D, Reset: 0x00, Name: YDATA1 Z-AXIS DATA REGISTERS Address: 0x0E, Reset: 0x00, Name: ZDATA3 Address: 0x0F, Reset: 0x00, Name: ZDATA2 Address: 0x10, Reset: 0x00, Name: ZDATA1 FIFO ACCESS REGISTER Address: 0x11, Reset: 0x00, Name: FIFO_DATA X-AXIS OFFSET TRIM REGISTERS Address: 0x1E, Reset: 0x00, Name: OFFSET_X_H Address: 0x1F, Reset: 0x00, Name: OFFSET_X_L Y-AXIS OFFSET TRIM REGISTERS Address: 0x20, Reset: 0x00, Name: OFFSET_Y_H Address: 0x21, Reset: 0x00, Name: OFFSET_Y_L Z-AXIS OFFSET TRIM REGISTERS Address: 0x22, Reset: 0x00, Name: OFFSET_Z_H Address: 0x23, Reset: 0x00, Name: OFFSET_Z_L ACTIVITY ENABLE REGISTER Address: 0x24, Reset: 0x00, Name: ACT_EN ACTIVITY THRESHOLD REGISTERS Address: 0x25, Reset: 0x00, Name: ACT_THRESH_H Address: 0x26, Reset: 0x00, Name: ACT_THRESH_L ACTIVITY COUNT REGISTER Address: 0x27, Reset: 0x01, Name: ACT_COUNT FILTER SETTINGS REGISTER Address: 0x28, Reset: 0x00, Name: Filter FIFO SAMPLES REGISTER Address: 0x29, Reset: 0x60, Name: FIFO_SAMPLES INTERRUPT PIN (INTx) FUNCTION MAP REGISTER Address: 0x2A, Reset: 0x00, Name: INT_MAP DATA SYNCHRONIZATION Address: 0x2B, Reset: 0x00, Name: Sync I2C SPEED, INTERRUPT POLARITY, AND RANGE REGISTER Address: 0x2C, Reset: 0x81, Name: Range POWER CONTROL REGISTER Address: 0x2D, Reset: 0x01, Name: POWER_CTL SELF TEST REGISTER Address: 0x2E, Reset: 0x00, Name: SELF_TEST RESET REGISTER Address: 0x2F, Reset: 0x00, Name: Reset RECOMMENDED SOLDERING PROFILE PCB FOOTPRINT PATTERN PACKAGING AND ORDERING INFORMATION OUTLINE DIMENSIONS BRANDING INFORMATION ORDERING GUIDE
