Datasheet ADIS16448 (Analog Devices) - 26
| Description | Compact, Precision Ten Degree of Freedom Inertial Sensor |
| Pages / Page | 26 / 26 — Data Sheet. ADIS16448. OUTLINE DIMENSIONS. 24.53 24.15 23.77. 20.150. … |
| Revision | H |
| File Format / Size | PDF / 619 Kb |
Data Sheet. ADIS16448. OUTLINE DIMENSIONS. 24.53 24.15 23.77. 20.150. 2.60. 6.70. BSC. 2.40 DIA. 2.00 BSC. 2.20. 2.00. 10-32 THREADED. 4.70. HOLE
Data Sheet ADIS16448 OUTLINE DIMENSIONS 24.53 24.15 23.77 20.150 2.60 6.70 BSC 2.40 DIA. BSC 2.00 BSC 2.20 2.00 10-32 THREADED BSC 4.70 HOLE 4.50 4.30 30.10 BSC 33.40 BSC 38.08 29.200 37.70 BSC 37.32 1.00 7.89 BSC 7.63 7.37 0.66 TOP VIEW BSC SIDE VIEW 2.30 BSC (2 PLCS) 12.50 BSC 2.30 BSC (2 PLCS) 19.55 BSC 2.96 7.57 2.70 BSC 1.00 BSC 2.44 PITCH 2.84 BSC (Pin Height) 11.10 10.80 10.50 10.23 5.18 BSC BSC D (PCB to Connector) 2013- END VIEW 14- 03-
Figure 27. 20-Lead Module with Connector Interface (ML-20-2) Dimensions shown in millimeters
ORDERING GUIDE Model1, 2 Temperature Range Package Description Package Option
ADIS16448BMLZ −40°C to +105°C 20-Lead Module with Connector Interface ML-20-2 ADIS16448BMLZ-P −40°C to +105°C 20-Lead Module with Connector Interface ML-20-2 1 Z = RoHS Compliant Part. 2 The ADIS16448BMLZ-P includes Parylene-C coating on the internal substrate and components, which has a thickness of 0.001” (±20%), along with a connector that has gold plating that is at least 0.00003 inches thick.
©2012–2017 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. D09946-0-4/17(F)
Rev. F | Page 25 of 25 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS USER REGISTERS USER INTERFACE READING SENSOR DATA Burst Read Function Burst Read Function with CRC SPI Read Test Sequence DEVICE CONFIGURATION Dual Memory Structure OUTPUT DATA REGISTERS GYROSCOPES ACCELEROMETERS MAGNETOMETERS BAROMETRIC PRESSURE REMOTE PRESSURE SENSING INTERNAL TEMPERATURE SYSTEM FUNCTIONS GLOBAL COMMANDS PRODUCT IDENTIFICATION SELF-TEST FUNCTION STATUS/ERROR FLAGS Magnetometer/Barometer New Data Indicator MEMORY MANAGEMENT Checksum Test INPUT/OUTPUT CONFIGURATION DATA READY INDICATOR GENERAL-PURPOSE INPUT/OUTPUT Example Input/Output Configuration DIGITAL PROCESSING CONFIGURATION GYROSCOPES/ACCELEROMETERS INPUT CLOCK CONFIGURATION Digital Filtering Dynamic Range MAGNETOMETER/BAROMETER New Data Indicators CALIBRATION GYROSCOPES Gyroscope Bias Error Estimation Gyroscope Bias Correction Factors Single Command Bias Correction ACCELEROMETERS Accelerometer Bias Error Estimation Accelerometer Bias Correction Factors Point of Percussion Alignment MAGNETOMETER CALIBRATION Hard Iron Correction Hard Iron Factors Soft Iron Effects FLASH UPDATES RESTORING FACTORY CALIBRATION ALARMS STATIC ALARM USE DYNAMIC ALARM USE ALARM REPORTING Alarm Example APPLICATIONS INFORMATION MOUNTING TIPS POWER SUPPLY CONSIDERATIONS ADIS16IMU2/PCBZ PC-BASED EVALUATION TOOLS OUTLINE DIMENSIONS ORDERING GUIDE
