Datasheet AVM-273HP+ - Full Version (Mini-Circuits) - 19
ManufacturerMini-Circuits
DescriptionWideband, Microwave 0.5W Monolithic Amplifier 50Ω 13 to 26.5 GHz
Pages / Page24 / 19 — DG1677-1. Outline Dimensions. PCB Land Pattern. Dimensions are in inches …
DG1677-1. Outline Dimensions. PCB Land Pattern. Dimensions are in inches (mm). Tolerances: 2 Pl. + .01; 3 Pl. + .005. Notes:
DG1677-1 Outline Dimensions PCB Land Pattern Dimensions are in inches (mm) Tolerances: 2 Pl + .01; 3 Pl + .005 Notes:
Case Style DG
Suggested Layout, Tolerance to be within .002 CASE # A B C MAX C MIN D E F G H J .197 .197 .039 .031 .008 .106 .106 .009 - .016 DG1677 (5.00) (5.00) (1.00) (0.80) (0.20) (2.70) (2.70) (0.23) - (0.40) CASE # K L M N P Q R S WT. GRAM .020 .193 .193 .110 .012 .035 .110 .008 DG1677 .05 (0.50) (4.90) (4.90) (2.79) (0.30) (0.89) (2.79) (0.20)
Dimensions are in inches (mm). Tolerances: 2 Pl. + .01; 3 Pl. + .005 Notes:
1. Case material: Plastic. 3. Termination finish: For RoHS Case Styles: Tin-Silver alloy plate over Nickel barrier transitioning to Matte-Tin. All models, (+) suffix. See Data sheet. For RoHS-5 Case Styles: Tin-Lead plate. All models, no (+) suffix. 98-DG Rev.: AF (09/22/17) M163935 File: 98-DG Sheet 11 of 15 Document Outline AVM-273HP+ Data Sheet View Data View Graphs Case Style PCB Layout Eval Board Enviromental Ratings
