Datasheet AD8145 (Analog Devices) - 22
Description | High Speed, Triple Differential Receiver with Comparators |
Pages / Page | 22 / 22 — Data Sheet. AD8145. OUTLINE DIMENSIONS. 5.10. 0.30. 5.00 SQ. 0.25. PIN 1. … |
Revision | B |
File Format / Size | PDF / 508 Kb |
Data Sheet. AD8145. OUTLINE DIMENSIONS. 5.10. 0.30. 5.00 SQ. 0.25. PIN 1. 4.90. 0.18. INDICATOR. 0.50. BSC. EXPOSED. 3.25. PAD. 3.10 SQ 2.95. 0.25 MIN
link to page 4
Data Sheet AD8145 OUTLINE DIMENSIONS 5.10 0.30 5.00 SQ 0.25 PIN 1 4.90 0.18 INDICATOR PIN 1 25 32 INDICATOR 24 1 0.50 BSC EXPOSED 3.25 PAD 3.10 SQ 2.95 17 8 16 9 0.50 0.25 MIN TOP VIEW BOTTOM VIEW 0.40 0.30 FOR PROPER CONNECTION OF 0.80 THE EXPOSED PAD, REFER TO 0.75 THE PIN CONFIGURATION AND 0.05 MAX FUNCTION DESCRIPTIONS 0.70 0.02 NOM SECTION OF THIS DATA SHEET. COPLANARITY 0.08 SEATING 0.20 REF PLANE A COMPLIANT TO JEDEC STANDARDS MO-220-WHHD. 112408-
Figure 45. 32-Lead Lead Frame Chip Scale Package [LFCSP_WQ] 5 mm × 5 mm Body, Very Very Thin Quad (CP-32-7) Dimensions shown in millimeters
ORDERING GUIDE Model1, 2 Temperature Range Package Description Package Option
AD8145YCPZ-R2 −40°C to +105°C 32-Lead Lead Frame Chip Scale Package [LFCSP_WQ] CP-32-7 AD8145YCPZ-RL −40°C to +105°C 32-Lead Lead Frame Chip Scale Package [LFCSP_WQ] CP-32-7 AD8145YCPZ-R7 −40°C to +105°C 32-Lead Lead Frame Chip Scale Package [LFCSP_WQ] CP-32-7 AD8145WYCPZ-R7 −40°C to +105°C 32-Lead Lead Frame Chip Scale Package [LFCSP_WQ] CP-32-7 AD8145-EVALZ Evaluation Board 1 Z = RoHS Compliant Part. 2 W = Qualified for Automotive Applications.
AUTOMOTIVE PRODUCTS
The AD8145W models are available with controlled manufacturing to support the quality and reliability requirements of automotive applications. Note that these automotive models may have specifications that differ from the commercial models; therefore, designers should review the Specifications section of this data sheet careful y. Only the automotive grade products shown are available for use in automotive applications. Contact your local Analog Devices account representative for specific product ordering information and to obtain the specific Automotive Reliability reports for these models.
©2006–2014 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. D06307-0-12/14(B)
Rev. B | Page 21 of 21 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE MAXIMUM POWER DISSIPATION ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION OVERVIEW BASIC CLOSED-LOOP GAIN CONFIGURATIONS TERMINATING THE INPUT INPUT CLAMPING PCB LAYOUT CONSIDERATIONS Minimizing Parasitic Feedback Reactances Maximizing Heat Removal DRIVING A CAPACITIVE LOAD POWER-DOWN COMPARATORS SYNC PULSE EXTRACTION USING COMPARATORS OUTLINE DIMENSIONS ORDERING GUIDE AUTOMOTIVE PRODUCTS
