Datasheet OPA196, OPA2196, OPA4196 - OPAx196 (Texas Instruments) - 7
ManufacturerTexas Instruments
Description36-V, Low-Power, Low Offset Voltage, Rail-to-Rail Operational Amplifier
Pages / Page49 / 7 — OPA196. , OPA2196. , OPA4196. www.ti.com. 6.7 Electrical Characteristics: …
File Format / SizePDF / 3.4 Mb
OPA196. , OPA2196. , OPA4196. www.ti.com. 6.7 Electrical Characteristics: VS = ±4 V to ±18 V (VS = 8 V to 36 V). PARAMETER
OPA196 , OPA2196 , OPA4196 www.ti.com 6.7 Electrical Characteristics: VS = ±4 V to ±18 V (VS = 8 V to 36 V) PARAMETER
link to page 24 link to page 11
SBOS869 – JULY 2017
at TA = 25°C, VCM = VOUT = VS / 2, and RL = 10 kΩ connected to VS / 2 (unless otherwise noted)
PARAMETER TEST CONDITIONS MIN TYP MAX UNIT OFFSET VOLTAGE
VOS Input offset voltage VS = ±18 V ±25 ±100 µV (V+) – 3.0 V < VCM < (V+) – 1.5 V See Common-Mode Voltage Range VS = ±18 V, ±25 ±100 VCM = (V+) – 1.5 V VS = ±18 V, VCM = (V+) – 3 V ±0.5 dVOS/dT Input offset voltage drift TA = –40°C to +125°C µV/°C VS = ±18 V, VCM = (V+) – 1.5 V ±0.8 Power-supply rejection PSRR T ratio A = –40°C to +125°C ±0.3 ±1 µV/V
INPUT BIAS CURRENT
IB Input bias current ±5 ±20 pA IOS Input offset current ±2 ±20 pA
NOISE
(V–) – 0.1 V < VCM < (V+) – 3 V f = 0.1 Hz to 10 Hz 1.4 En Input voltage noise µVPP (V+) – 1.5 V < VCM < (V+) + 0.1 V f = 0.1 Hz to 10 Hz 7 f = 100 Hz 18 (V–) – 0.1 V < VCM < (V+) – 3 V Input voltage noise f = 1 kHz 15 en nV/√Hz density f = 100 Hz 53 (V+) – 1.5 V < VCM < (V+) + 0.1 V f = 1 kHz 24 Input current noise in f = 1 kHz 1.5 fA/√Hz density
INPUT VOLTAGE
Common-mode voltage VCM (V–) – 0.1 (V+) + 0.1 V range VS = ±18 V, 120 140 (V–) – 0.1 V < VCM < (V+) – 3 V VS = ±18 V, T Common-mode A = –40°C to +125°C 114 126 CMRR (V–) < VCM < (V+) – 3 V dB rejection ratio V 96 120 S = ±18 V, (V+) – 1.5 V < VCM < (V+) TA = –40°C to +125°C 86 100 (V+) – 3 V < VCM < (V+) – 1.5 V See Typical Characteristics
INPUT IMPEDANCE
ZID Differential 100 || 1.6 MΩ || pF 1013Ω || ZIC Common-mode 1 || 6.4 pF
OPEN-LOOP GAIN
VS = ±18 V, 124 134 (V–) + 0.6 V < VO < (V+) – 0.6 V, R TA = –40°C to +125°C 114 126 L = 2 kΩ AOL Open-loop voltage gain dB VS = ±18 V, 126 140 (V–) + 0.3 V < VO < (V+) – 0.3 V, R TA = –40°C to +125°C 120 134 L = 10 kΩ Copyright © 2017, Texas Instruments Incorporated Submit Documentation Feedback 7 Product Folder Links: OPA196 OPA2196 OPA4196 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information: OPA196 6.5 Thermal Information: OPA2196 6.6 Thermal Information: OPA4196 6.7 Electrical Characteristics: VS = ±4 V to ±18 V (VS = 8 V to 36 V) 6.8 Electrical Characteristics: VS = ±2.25 V to ±4 V (VS = 4.5 V to 8 V) 6.9 Typical Characteristics 7 Detailed Description 7.1 Overview 7.2 Functional Block Diagram 7.3 Feature Description 7.3.1 Input Protection Circuitry 7.3.2 EMI Rejection 7.3.3 Phase Reversal Protection 7.3.4 Thermal Protection 7.3.5 Capacitive Load and Stability 7.3.6 Common-Mode Voltage Range 7.3.7 Electrical Overstress 7.3.8 Overload Recovery 7.4 Device Functional Modes 8 Application and Implementation 8.1 Application Information 8.2 Typical Applications 8.2.1 Low-side Current Measurement 8.2.1.1 Design Requirements 8.2.1.2 Detailed Design Procedure 8.2.1.3 Application Curves 8.2.2 16-Bit Precision Multiplexed Data-Acquisition System 8.2.2.1 Design Requirements 8.2.2.2 Detailed Design Procedure 8.2.3 Slew Rate Limit for Input Protection 9 Power-Supply Recommendations 10 Layout 10.1 Layout Guidelines 10.2 Layout Example 11 Device and Documentation Support 11.1 Device Support 11.1.1 Development Support 11.1.1.1 TINA-TI (Free Software Download) 11.1.1.2 TI Precision Designs 11.2 Documentation Support 11.2.1 Related Documentation 11.3 Related Links 11.4 Receiving Notification of Documentation Updates 11.5 Community Resources 11.6 Trademarks 11.7 Electrostatic Discharge Caution 11.8 Glossary 12 Mechanical, Packaging, and Orderable Information
