Datasheet ATmega161, ATmega161L (Atmel) - 42
ManufacturerAtmel
Description8-bit AVR Microcontroller with 16K Bytes of In-System Programmable Flash
Pages / Page159 / 42 — Timer/Counter0 Control Register – TCCR0. FOC0. PWM0. COM01. COM00. CTC0. …
Timer/Counter0 Control Register – TCCR0. FOC0. PWM0. COM01. COM00. CTC0. CS02. CS01. CS00. TCCR0. Timer/Counter2 Control Register – TCCR2
Timer/Counter0 Control Register – TCCR0 FOC0 PWM0 COM01 COM00 CTC0 CS02 CS01 CS00 TCCR0 Timer/Counter2 Control Register – TCCR2
link to page 44
Bit 7 6 5 4 3 2 1 0 $33 ($53)
Read/Write R/W R/W R/W R/W R/W R/W R/W R/W Initial Value 0 0 0 0 0 0 0 0
Bit 7 6 5 4 3 2 1 0 $27 ($47)
FOC2 PWM2 COM21 COM20 CTC2 CS22 CS21 CS20 TCCR2
• Bi t 7 – FOC0/FOC2: Force Output Compare
Writing a logical “1” to this bit forces a change in the compare match output pin PB0 (Timer/Counter0) and PB1 (Timer/Counter2) according to the values already set in COMn1 and COMn0. If the COMn1 and COMn0 bits are written in the same cycle as FOC0/FOC2, the new settings will not take effect until the next compare match or Forced Output Compare Match occurs. The Force Output Compare bit can be used to change the output pin without waiting for a compare match in the timer. The automatic action programmed in COMn1 and COMn0 happens as if a Compare Match had occurred, but no interrupt is generated and the Timer/Counters will not be cleared even if CTC0/CTC2 is set. The FOC0/FOC2 bits will always be read as zero. The setting of the FOC0/FOC2 bits has no effect in PWM mode.
• Bi t 6 – PWM0/PWM2: Pulse Width Modulator Enable
When set (one), this bit enables PWM mode for Timer/Counter0 or Timer/Counter2. This mode is described on page 44.
• Bits 5, 4 – COM01, COM00/COM21, COM20: Compare Output Mode, Bits 1 and 0
The COMn1 and COMn0 control bits determine any output pin action following a com- pare match in Timer/Counter0 or Timer/Counter2. Output pin actions affect pins PB0(OC0) or PB1(OC2). This is an alternative function to an I/O port and the corre- sponding direction control bit must be set (one) to control an output pin. The control configuration is shown in Table 9.
Table 9.
Compare Mode Select(1)(2)
COMn1 COMn0 Description
0 0 Timer/Counter disconnected from output pin OCn. 0 1 Toggle the OCn output line. 1 0 Clear the OCn output line (to zero). 1 1 Set the OCn output line (to one). Notes: 1. In PWM mode, these bits have a different function. Refer to Table 12 for a detailed description. 2. n = 0 or 2
• Bi t 3 – CTC0/CTC2: Clear Timer/Counter on Compare Match
When the CTC0 or CTC2 control bit is set (one), Timer/Counter0 or Timer/Counter2 is reset to $00 in the CPU clock cycle after a compare match. If the control bit is cleared, the Timer/Counter continues counting and is unaffected by a compare match. When a
42 ATmega161(L)
1228D–AVR–02/07 Document Outline Features Disclaimer Pin Configuration Description Block Diagram Pin Descriptions VCC GND Port A (PA7..PA0) Port B (PB7..PB0) Port C (PC7..PC0) Port D (PD7..PD0) Port E (PE2..PE0) RESET XTAL1 XTAL2 Crystal Oscillator Architectural Overview The General Purpose Register File The X-register, Y-register and Z-register ALU - Arithmetic Logic Unit Self-programmable Flash Program Memory EEPROM Data Memory SRAM Data Memory Program and Data Addressing Modes Register Direct, Single Register Rd Register Direct, Two Registers Rd and Rr I/O Direct Data Direct Data Indirect with Displacement Data Indirect Data Indirect with Pre- decrement Data Indirect with Post- increment Constant Addressing Using the LPM Instruction Indirect Program Addressing, IJMP and ICALL Relative Program Addressing, RJMP and RCALL Direct Program Addressing, JMP and CALL Memory Access Times and Instruction Execution Timing l/O Memory Status Register - SREG Stack Pointer - SP Reset and Interrupt Handling Reset Sources Power-on Reset External Reset Watchdog Reset MCU Status Register - MCUSR Interrupt Handling Interrupt Response Time General Interrupt Mask Register - GIMSK General Interrupt Flag Register - GIFR Timer/Counter Interrupt Mask Register - TIMSK Timer/Counter Interrupt Flag Register - TIFR External Interrupts MCU Control Register - MCUCR Extended MCU Control Register - EMCUCR Sleep Modes Idle Mode Power-down Mode Power-save Mode Timer/Counters Timer/Counter Prescalers Special Function IO Register - SFIOR 8-bit Timer/Counters T/C0 and T/C2 Timer/Counter0 Control Register - TCCR0 Timer/Counter2 Control Register - TCCR2 Timer Counter0 - TCNT0 Timer/Counter2 - TCNT2 Timer/Counter0 Output Compare Register - OCR0 Timer/Counter2 Output Compare Register - OCR2 Timer/Counters 0 and 2 in PWM Mode PWM Modes (Up/Down and Overflow) Asynchronous Status Register - ASSR Asynchronous Operation of Timer/Counter2 Timer/Counter1 Timer/Counter1 Control Register A - TCCR1A Timer/Counter1 Control Register B - TCCR1B Timer/Counter1 Register - TCNT1H AND TCNT1L Timer/Counter1 Output Compare Register - OCR1AH AND OCR1AL Timer/Counter1 Output Compare Register - OCR1BH AND OCR1BL Timer/Counter1 Input Capture Register - ICR1H AND ICR1L Timer/Counter1 in PWM Mode Watchdog Timer Watchdog Timer Control Register - WDTCR EEPROM Read/Write Access EEPROM Address Register - EEARH and EEARL EEPROM Data Register - EEDR EEPROM Control Register - EECR Prevent EEPROM Corruption Serial Peripheral Interface - SPI SS Pin Functionality Data Modes SPI Control Register - SPCR SPI Status Register - SPSR SPI Data Register - SPDR UARTs Data Transmission Data Reception Multi-processor Communication Mode UART Control UART0 I/O Data Register - UDR0 UART1 I/O Data Register - UDR1 UART0 Control and Status Registers - UCSR0A UART1 Control and Status Registers - UCSR1A UART0 Control and Status Registers - UCSR0B UART1 Control and Status Registers - UCSR1B Baud Rate Generator UART0 and UART1 High Byte Baud Rate Register UBRRHI UART0 Baud Rate Register Low Byte - UBRR0 UART1 Baud Rate Register Low Byte - UBRR1 Double-speed Transmission The Baud Rate Generator in Double UART Speed Mode Analog Comparator Analog Comparator Control and Status Register - ACSR Internal Voltage Reference Voltage Reference Enable Signals and Start- up Time Interface to External Memory MCU Control Register - MCUCR Extended MCU Control Register - EMCUCR Using the External Memory Interface I/O Ports Port A Port A Data Register - PORTA Port A Data Direction Register - DDRA Port A Input Pins Address - PINA Port A as General Digital I/O Port A Schematics Port B Port B Data Register - PORTB Port B Data Direction Register - DDRB Port B Input Pins Address - PINB Port B as General Digital I/O Alternate Functions of Port B Port B Schematics Port C Port C Data Register - PORTC Port C Data Direction Register - DDRC Port C Input Pins Address - PINC Port C as General Digital I/O Port C Schematics Port D Port D Data Register - PORTD Port D Data Direction Register - DDRD Port D Input Pins Address - PIND Port D as General Digital I/O Alternate Functions of Port D Port D Schematics Port E Port E Data Register - PORTE Port E Data Direction Register - DDRE Port E Input Pins Address - PINE Port E as General Digital I/O Alternate Functions of Port E Port E Schematics Memory Programming Boot Loader Support Entering the Boot Loader Program Capabilities of the Boot Loader Self-programming the Flash Setting the Boot Loader Lock bits by SPM Performing Page Erase by SPM Fill the Temporary Buffer Perform a Page Write Addressing the FLASH during Self-programming Store Program Memory Control Register - SPMCR EEPROM Write Prevents Writing to SPMCR Reading the Fuse and Lock bits from Software Program Memory Lock bits Fuse bits Signature Bytes Programming the Flash and EEPROM Parallel Programming Signal Names Enter Programming Mode Chip Erase Programming the Flash Programming the EEPROM Reading the Flash Reading the EEPROM Programming the Fuse Bits Programming the Lock Bits Reading the Fuse and Lock Bits Reading the Signature Bytes Parallel Programming Characteristics Serial Downloading Serial Programming Algorithm Data Polling Flash Data Polling EEPROM Serial Programming Characteristics Electrical Characteristics Absolute Maximum Ratings* DC Characteristics External Clock Drive Waveforms External Data Memory Timing Typical Characteristics Register Summary Instruction Set Summary (Continued) Ordering Information Packaging Information 44A 40P6 Errata ATmega161 Rev. E Data Sheet Change Log for ATmega161 Changes from Rev. 1228C-08 /02 to Rev. 1228D-02/07 Changes from Rev. 1228B-09/01 to Rev. 1228C-08/02 Table of Contents
