Datasheet ATtiny15L (Atmel) - 76
ManufacturerAtmel
Description8-bit AVR Microcontroller with 1K Byte Flash
Pages / Page86 / 76 — ATtiny15L Instruction Set Summary. Mnemonic. Operands. Description. …
ATtiny15L Instruction Set Summary. Mnemonic. Operands. Description. Operation. Flags. # Clocks. ARITHMETIC AND LOGIC INSTRUCTIONS
ATtiny15L Instruction Set Summary Mnemonic Operands Description Operation Flags # Clocks ARITHMETIC AND LOGIC INSTRUCTIONS
ADD Rd, Rr Add Two Registers Rd ← Rd + Rr Z,C,N,V,H 1 ADC Rd, Rr Add with Carry Two Registers Rd ← Rd + Rr + C Z,C,N,V,H 1 SUB Rd, Rr Subtract Two Registers Rd ← Rd - Rr Z,C,N,V,H 1 SUBI Rd, K Subtract Constant from Register Rd ← Rd - K Z,C,N,V,H 1 SBC Rd, Rr Subtract with Carry Two Registers Rd ← Rd - Rr - C Z,C,N,V,H 1 SBCI Rd, K Subtract with Carry Constant from Reg. Rd ← Rd - K - C Z,C,N,V,H 1 AND Rd, Rr Logical AND Registers Rd ← Rd • Rr Z,N,V 1 ANDI Rd, K Logical AND Register and Constant Rd ← Rd • K Z,N,V 1 OR Rd, Rr Logical OR Registers Rd ← Rd v Rr Z,N,V 1 ORI Rd, K Logical OR Register and Constant Rd ← Rd v K Z,N,V 1 EOR Rd, Rr Exclusive OR Registers Rd ← Rd⊕Rr Z,N,V 1 COM Rd One’s Complement Rd ← $FF - Rd Z,C,N,V 1 NEG Rd Two’s Complement Rd ← $00 - Rd Z,C,N,V,H 1 SBR Rd, K Set Bit(s) in Register Rd ← Rd v K Z,N,V 1 CBR Rd, K Clear Bit(s) in Register Rd ← Rd • (FFh - K) Z,N,V 1 INC Rd Increment Rd ← Rd + 1 Z,N,V 1 DEC Rd Decrement Rd ← Rd - 1 Z,N,V 1 TST Rd Test for Zero or Minus Rd ← Rd • Rd Z,N,V 1 CLR Rd Clear Register Rd ← Rd⊕Rd Z,N,V 1 SER Rd Set Register Rd ← $FF None 1
BRANCH INSTRUCTIONS
RJMP k Relative Jump PC ← PC + k + 1 None 2 RCALL k Relative Subroutine Call PC ← PC + k + 1 None 3 RET Subroutine Return PC ← STACK None 4 RETI Interrupt Return PC ← STACK I 4 CPSE Rd, Rr Compare, Skip if Equal if (Rd = Rr) PC ← PC + 2 or 3 None 1/2 CP Rd, Rr Compare Rd - Rr Z,N,V,C,H 1 CPC Rd, Rr Compare with Carry Rd - Rr - C Z,N,V,C,H 1 CPI Rd, K Compare Register with Immediate Rd - K Z,N,V,C,H 1 SBRC Rr, b Skip if Bit in Register Cleared if (Rr(b) = 0) PC ← PC + 2 or 3 None 1/2 SBRS Rr, b Skip if Bit in Register is Set if (Rr(b) = 1) PC ← PC + 2 or 3 None 1/2 SBIC P, b Skip if Bit in I/O Register Cleared if (P(b) = 0) PC ← PC + 2 or 3 None 1/2 SBIS P, b Skip if Bit in I/O Register is Set if (P(b) = 1) PC ← PC + 2 or 3 None 1/2 BRBS s, k Branch if Status Flag Set if (SREG(s) = 1) then PC ← PC + k + 1 None 1/2 BRBC s, k Branch if Status Flag Cleared if (SREG(s) = 0) then PC ← PC + k + 1 None 1/2 BREQ k Branch if Equal if (Z = 1) then PC ← PC + k + 1 None 1/2 BRNE k Branch if Not Equal if (Z = 0) then PC ← PC + k + 1 None 1/2 BRCS k Branch if Carry Set if (C = 1) then PC ← PC + k + 1 None 1/2 BRCC k Branch if Carry Cleared if (C = 0) then PC ← PC + k + 1 None 1/2 BRSH k Branch if Same or Higher if (C = 0) then PC ← PC + k + 1 None 1/2 BRLO k Branch if Lower if (C = 1) then PC ← PC + k + 1 None 1/2 BRMI k Branch if Minus if (N = 1) then PC ← PC + k + 1 None 1/2 BRPL k Branch if Plus if (N = 0) then PC ← PC + k + 1 None 1/2 BRGE k Branch if Greater or Equal, Signed if (N ⊕ V= 0) then PC ← PC + k + 1 None 1/2 BRLT k Branch if Less Than Zero, Signed if (N ⊕ V= 1) then PC ← PC + k + 1 None 1/2 BRHS k Branch if Half-carry Flag Set if (H = 1) then PC ← PC + k + 1 None 1/2 BRHC k Branch if Half-carry Flag Cleared if (H = 0) then PC ← PC + k + 1 None 1/2 BRTS k Branch if T-flag Set if (T = 1) then PC ← PC + k + 1 None 1/2 BRTC k Branch if T-flag Cleared if (T = 0) then PC ← PC + k + 1 None 1/2 BRVS k Branch if Overflow Flag is Set if (V = 1) then PC ← PC + k + 1 None 1/2 BRVC k Branch if Overflow Flag is Cleared if (V = 0) then PC ← PC + k + 1 None 1/2 BRIE k Branch if Interrupt Enabled if (I = 1) then PC ← PC + k + 1 None 1/2 BRID k Branch if Interrupt Disabled if (I = 0) then PC ← PC + k + 1 None 1/2
DATA TRANSFER INSTRUCTIONS
LD Rd, Z Load Register Indirect Rd ← (Z) None 2 ST Z, Rr Store Register Indirect (Z) ← Rr None 2 MOV Rd, Rr Move between Registers Rd ← Rr None 1 LDI Rd, K Load Immediate Rd ← K None 1 IN Rd, P In Port Rd ← P None 1 OUT P, Rr Out Port P ← Rr None 1 LPM Load Program Memory R0 ← (Z) None 3
BIT AND BIT-TEST INSTRUCTIONS
SBI P, b Set Bit in I/O Register I/O(P,b) ← 1 None 2
76 ATtiny15L
1187H–AVR–09/07 Document Outline Features Pin Configuration Description Block Diagram Pin Descriptions VCC GND Port B (PB5..PB0) Analog Pins Internal Oscillators ATtiny15L Architectural Overview The General Purpose Register File The ALU - Arithmetic Logic Unit The Flash Program Memory The Program and Data Addressing Modes Register Direct, Single- register Rd Register Indirect Register Direct, Two Registers Rd and Rr I/O Direct Relative Program Addressing, RJMP and RCALL Constant Addressing using the LPM Instruction Subroutine and Interrupt Hardware Stack The EEPROM Data Memory Memory Access and Instruction Execution Timing I/O Memory The Status Register - SREG Reset and Interrupt Handling ATtiny15L Reset Sources Power-on Reset External Reset Brown-out Detection Watchdog Reset MCU Status Register - MCUSR Internal Voltage Reference Voltage Reference Enable Signals and Start-up Time Interrupt Handling Interrupt Response Time The General Interrupt Mask Register - GIMSK The General Interrupt Flag Register - GIFR The Timer/Counter Interrupt Mask Register - TIMSK The Timer/Counter Interrupt Flag Register - TIFR External Interrupt Pin Change Interrupt The MCU Control Register - MCUCR Sleep Modes Idle Mode ADC Noise Reduction Mode Power-down Mode Tuneable Internal RC Oscillator The System Clock Oscillator Calibration Register - OSCCAL Internal PLL for Fast Peripheral Clock Generation Timer/Counters The Timer/Counter0 Prescaler The Timer/Counter1 Prescaler The Special Function IO Register - SFIOR The 8-bit Timer/Counter0 The Timer/Counter0 Control Register - TCCR0 The Timer Counter 0 - TCNT0 The 8-bit Timer/Counter1 The Timer/Counter1 Control Register - TCCR1 The Timer/Counter1 - TCNT1 Timer/Counter1 Output Compare RegisterA - OCR1A Timer/Counter1 in PWM Mode Timer/Counter1 Output Compare RegisterB - OCR1B The Watchdog Timer The Watchdog Timer Control Register - WDTCR EEPROM Read/Write Access The EEPROM Address Register - EEAR The EEPROM Data Register - EEDR The EEPROM Control Register - EECR Preventing EEPROM Corruption The Analog Comparator The Analog Comparator Control and Status Register - ACSR The Analog-to-Digital Converter, Analog Multiplexer, and Gain Stages Features Operation Prescaling and Conversion Timing ADC Noise Canceler Function The ADC Multiplexer Selection Register - ADMUX The ADC Control and Status Register - ADCSR The ADC Data Register - ADCL and ADCH ADLAR = 0 ADLAR = 1 Scanning Multiple Channels ADC Noise-canceling Techniques ADC Characteristics I/O Port B Unconnected Pins Alternative Functions of Port B The Port B Data Register - PORTB The Port B Data Direction Register - DDRB The Port B Input Pins Address - PINB PORT B as General Digital I/O Alternate Functions of Port B Memory Programming Program and Data Memory Lock Bits Fuse Bits Signature Bytes Calibration Byte Programming the Flash High-voltage Serial Programming High-voltage Serial Programming Algorithm High-voltage Serial Programming Characteristics Low-voltage Serial Downloading Low-voltage Serial Programming Algorithm Data Polling Low-voltage Serial Programming Characteristics Electrical Characteristics Absolute Maximum Ratings DC Characteristics Typical Characteristics ATtiny15L Register Summary ATtiny15L Instruction Set Summary Ordering Information Packaging Information 8P3 8S2 Datasheet revision history Rev H - 09/07 Rev G - 06/07 Rev F - 06/05 Table of Contents
