LTC6655 Typical applicaTionsOutput Voltage Boost VIN V VOUT IN VOUT_F VOUT + 0.5V TO 13.2V 2.5V TO 4.5V C1 LTC6655-2.5 R C2 1µF 10µF SHDN VOUT_S R = 0k to 1k GND 6655 TA07 VOUT = VOLTAGE OPTION + 0.002 • R FOR R USE A POTENTIOMETER THAT THIS EXAMPLE USES 2.5V AS THE CAN HANDLE 2mA, IS LOW NOISE AND VOLTAGE OPTION HAS A LOW TEMPERATURE COEFFICIENT Low Noise Precision Voltage Boost Circuit VIN V VOUT IN VOUT_F VOUT + 0.5V TO 13.2V 5V C1 V LTC6655-2.5 IN C2 LT1677 1µF R1 ++ 10µF SHDN VOUT_S 10k –– RLOAD GND R2 10k R3 6655 TA08 5k VOUT = VOLTAGE OPTION • (1 + R1/R2) FOR R1, R2 AND R3 USE LT5400-1. THIS EXAMPLE USES 2.5V AS THE WITH A PRECISION ARRAY THE VOLTAGE OPTION MATCHING AND LOW TC WILL HELP PRESERVE LOW DRIFT. R3 = R1||R2 R3 IS MADE WITH TWO PRALLEL 10k RESISTORS, AVAILABLE IN THE LT5400-1 Ultralow 1/f Noise Reference Buffer V LT3042 IN IN 6V ±5% 4.7µF 100µA – EN/UV + PGFB OUT VOUT = 5V I 1,2 OUT(MAX) 6,7 200mA PG OUTS LTC6655-5 SET GND ILIM 4.7µF 3,4,5,8 1k 6655 TA08 10µF 49.9k 4.7µF 6655ff For more information www.linear.com/LTC6655 21 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Available Options Electrical Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
