Datasheet ADR121, ADR125, ADR127 (Analog Devices)
| Description | Precision, Micropower LD0 1.25 VOUT Voltage Reference in TSOT |
| Pages / Page | 20 / 1 — Precision, Micropower LDO Voltage. References in TSOT. … |
| Revision | B |
| File Format / Size | PDF / 612 Kb |
Precision, Micropower LDO Voltage. References in TSOT. ADR121/ADR125/ADR127. FEATURES. PIN CONFIGURATION. Initial accuracy. NC1 1
Precision, Micropower LDO Voltage References in TSOT ADR121/ADR125/ADR127 FEATURES PIN CONFIGURATION Initial accuracy NC1 1 NC1 6 A grade: ±0.24% ADR12x GND 2 TOP VIEW 5 NC1 B grade: ±0.12% (Not to Scale) Maximum temperature coefficient VIN 3 4 VOUT A grade: 25 ppm/°C NC = NO CONNECT
01
B grade: 9 ppm/°C
0 5-
1 MUST BE LEFT FLOATING
72
Low dropout: 300 mV for ADR121/ADR125
05 Figure 1.
High output current: +5 mA/−2 mA Low typical operating current: 85 μA Input range: 2.7 V to 18 V for ADR127 Temperature range: −40°C to +125°C Tiny TSOT (UJ-6) package APPLICATIONS Battery-powered instrumentation Portable medical equipment Data acquisition systems Automotive GENERAL DESCRIPTION
The ADR121/ADR125/ADR127 are a family of micropower, The ADR12x is a low dropout voltage reference, requiring only high precision, series mode, band gap references with sink and 300 mV for the ADR121/ADR125 and 1.45 V for the ADR127 source capability. The parts feature high accuracy and low above the nominal output voltage on the input to provide a power consumption in a tiny package. The ADR12x design stable output voltage. This low dropout performance, coupled includes a patented temperature-drift curvature correction with the low 85 μA operating current, makes the ADR12x ideal technique that minimizes the nonlinearities in the output for battery-powered applications. voltage vs. temperature characteristics. Available in an extended industrial temperature range of −40°C to +125°C, the ADR121/ADR125/ADR127 are housed in the tiny TSOT (UJ-6) package.
Rev. B Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©2006–2008 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES APPLICATIONS PIN CONFIGURATION GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ADR121 ELECTRICAL CHARACTERISTICS ADR125 ELECTRICAL CHARACTERISTICS ADR127 ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS TERMINOLOGY THEORY OF OPERATION POWER DISSIPATION CONSIDERATIONS INPUT CAPACITOR OUTPUT CAPACITOR APPLICATIONS INFORMATION BASIC VOLTAGE REFERENCE CONNECTION STACKING REFERENCE ICs FOR ARBITRARY OUTPUTS NEGATIVE PRECISION REFERENCE WITHOUT PRECISION RESISTORS GENERAL-PURPOSE CURRENT SOURCE OUTLINE DIMENSIONS ORDERING GUIDE
